regulated fuel return system. - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 8 (permalink) Old 06-03-2019, 07:58 PM Thread Starter
Skyhigh001's Avatar
Garage
I did a fuel bowl delete so I installed the Sinister regulated return system on my 01 7.3, before I installed the system I was getting around 20mpg, now I am getting 13ish. I set the regulator to 68psi. does anyone have it set different to where the mpg is not affected?
Skyhigh001 is offline
post #2 of 8 (permalink) Old 06-05-2019, 07:16 AM
Re: regulated fuel return system.
Check your system for leaks, shouldn’t be dropping mileage like that. Swapping to e fuel shouldn’t affect mileage, Perhaps a right foot adjustment is needed...heh heh.
j
Tan white tan 97 ECLB, D60 RSK SD springs front, airs bags rear, E4OD 4:10, intake, DP 4” exhaust
Red 97 F250 CC 3:55, D60 Air Locker front, 175/80s, T500, TW files, Tymar, SD I/C, 6.0 fan, E-air, E-Fuel, RSK, SD springs front/rear, 145 litre rear tank (now ZF-5
JCart is offline
post #3 of 8 (permalink) Old 06-11-2019, 08:01 AM Thread Starter
Skyhigh001's Avatar
Garage
Sorry for the late response, but I have checked everywhere and found no leaks my only other option is injector O rings, which that's the only thing I have not checked. I am getting no fuel in oil or coolant, and with the right foot I dont go over 1000egts and normally cruise around at 5psi of boost, a little bit more now that I straight piped her. I have bought a FASS lift pump that's fully adjustable was goin to try maybe the stock pump is struggling to over come the pressure of the regulator.
post #4 of 8 (permalink) Old 06-13-2019, 11:59 AM
How many miles have you put on the truck since you installed the regulated return? When I did Corey's 4 line feed it took awhile for all of the air to bleed through the system.
2002 F-250 ECSB ZF6
FF 205/30's, KC 300X 63/73 .84, South Bend Clutch, CNC Fab 4 Line Feed, AEM 400LPH, PHP Tuned
02_7.three is offline
post #5 of 8 (permalink) Old 06-17-2019, 06:21 PM Thread Starter
Skyhigh001's Avatar
Garage
It's been close to 1k miles since I installed it.
post #6 of 8 (permalink) Old 06-19-2019, 02:14 PM
Have you checked actual driving psi and not just at idle? Low fuel pressure could be causing it.
2002 F-250 ECSB ZF6
post #7 of 8 (permalink) Old 06-22-2019, 10:29 PM Thread Starter
Skyhigh001's Avatar
Garage
No I have not that's a good idea thank you, I just know when its warm and at idle pressure is set to 68 I will have to check my running pressure with my scanner. Thanks
post #8 of 8 (permalink) Old 06-23-2019, 05:48 PM
wow that is a drastic drop, I'll be subscribed to this one. have been thinking about this switch over on my 96.
compression ignition rules
96F250SCshorty is offline
