Terrible fuel mileage - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 9 (permalink) Old 05-19-2019, 01:05 AM Thread Starter
Hey everyone! I'm sorta new to the diesel game so I'm here to ask advice from you experts!
I have a '03 F250 4 door short bed 4x4. Ive been getting awful fuel mileage lately and I'm unsure why. Heres a list of everything I've checked/replaced:
EBPS and tube - cleaned
Replaced all things brakes - nothing stuck
cold air intake - replaced filter
315/70/17 Cooper discover M/T @ 60 psi
4" exhaust from headers back
Fresh oil change with rotella T5
New glow plugs
Edge programmer on tow tune
Add a bottle of standyne to every tank
After checking the obvious, I'm still getting 9.4 MPG. No load, DD usually 10 - 15 miles per day and speeds averaging 30 MPH and I accelerate lightly. I understand that these trucks shine at 55 MPH but that's rare up here in Alaska. We just switched from winter blend to summer blend diesel up here but I didn't see a difference in performance or fuel efficiency.
Any suggestions?
XxNitewolfxX is offline
post #2 of 9 (permalink) Old 05-19-2019, 11:06 AM
alleged moderator
tjctransport's Avatar
Re: Terrible fuel mileage
welcome to PSN.
you did not mention axle ratio, but even without that i can tell you the tire size is not good for mileage. also, the edge tuner is not helping either.
my untuned 02 with 265/75/16 tires gets 12-13 at 45 mph.
tom
tjctransport is offline
post #3 of 9 (permalink) Old 05-19-2019, 01:27 PM
s10mike's Avatar
I would check to make sure that none of your brakes are dragging. The calipers in these trucks suck. Also the slide pins freeze up and make the pads drag.
s10mike is offline
post #4 of 9 (permalink) Old 05-19-2019, 04:37 PM
Project Shamu
Lt.Dan's Avatar
Check for boost leaks.
1996 Cali F350 CCFB, 7.3 PSD, 2wd SAS, w/ 372,000 miles.
New Motor at 352,000, DieselSite Legendary Trans at 356,000 and many more
1983 F150 SCSB Flareside, 302 w/ AOD Trans
2002 F450 SCFB, 7.3 PSD 2wd w/ 144,000 miles
SOLD
Lt.Dan is offline
post #5 of 9 (permalink) Old 05-21-2019, 01:48 AM Thread Starter
Originally Posted by tjctransport View Post
welcome to PSN.
Yeah I'm unsure of the gearing. That's one thing I plan on looking into this summer. As for the tuner, I actually get worse mileage at stock.
I just replaced the whole brake system about 2 months ago and checked last weekend, nothing sticking.
I'll for sure do that. Is there any way I can do this or does it require a shop/special tool?
post #6 of 9 (permalink) Old 05-21-2019, 03:27 AM
Project Shamu
Lt.Dan's Avatar
Google/Youtube "How to make a boost leak detector", several different ways to go about it, but pretty easy/straight forward.
SOLD
Lt.Dan is offline
post #7 of 9 (permalink) Old 05-22-2019, 12:59 AM
s10mike's Avatar
Im 99.9% sure your gears are 3.73s. Boost leak is a good place to check, like mentioned
s10mike is offline
post #8 of 9 (permalink) Old 05-22-2019, 01:04 AM
s10mike's Avatar
FWIW, i have basically the same truck, same tire size with a PHP Hydra tuner, Tony Wildman economy tune. Im getting a fuzz over 16mpg in town, fuzz over 20mpg highway. I never got much over 12mpg with ANY performance or towing tunes
s10mike is offline
post #9 of 9 (permalink) Old 05-22-2019, 01:56 PM
dmd
Member
dmd's Avatar
Is the thermostat stuck open and not letting the engine fully warm up? That will kill mileage when everything else
is fine.
'00 F350 Supercrewzer Lariet, PSD, Auto, 3.73, CC, 4x4, SWB, SRW, 160/30 w/Gearhead Tunes, 38r, S&B CAI, 4-inch turbo back exhaust, Adrenaline HPOP, BTS Trans, in-tank/pre-pump mod, heater/AC mod, Excursion sound panels, Harvest Gold and Black / Packages: Trailer Tow, Camper, Off-Road.
dmd is offline
Similar Threads
Terrible fuel economy StrokeThese 1994-1997 Power Stroke Technical Info 4 04-19-2015 07:31 PM
6.0 terrible fuel economy - help - IIvonnyII 6.0L Power Stroke Technical Info 55 12-08-2012 08:23 AM
Terrible Gas mileage!! splatranger95 6.0L Power Stroke Technical Info 20 05-14-2012 04:56 PM
few mods and terrible fuel milage customsound 6.4L Power Stroke - Aftermarket & Performance 13 08-04-2011 02:00 PM
92 non turbo Terrible fuel Milage 97strokeonit 6.9 - 7.3L IDI Diesels 83-93 Model Years 3 02-13-2011 10:14 AM
