Idle a little high . - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 5 (permalink) Old 04-25-2019, 09:44 PM Thread Starter
Philhan69@aol.com's Avatar
Just wandering if any one else's truck idles high after a couple thousand miles after injectors and hpop replacement. My truck runs the best it ever has now but seems to be idling high the last few days. Thanks for any info.
Sent from my SM-G955U using Tapatalk
post #2 of 5 (permalink) Old 04-25-2019, 10:09 PM
dmd
Member
dmd's Avatar
Re: Idle a little high .
What do you define as high?
'00 F350 Supercrewzer Lariet, PSD, Auto, 3.73, CC, 4x4, SWB, SRW, 160/30 w/Gearhead Tunes, 38r, S&B CAI, 4-inch turbo back exhaust, Adrenaline HPOP, BTS Trans, in-tank/pre-pump mod, heater/AC mod, Excursion sound panels, Harvest Gold and Black / Packages: Trailer Tow, Camper, Off-Road.
dmd is offline
post #3 of 5 (permalink) Old 04-25-2019, 11:45 PM Thread Starter
Most of the time its idling about 750 the last unless it's cold then it idles high till I touch the brake. Lately it stays around 950 to 975. Sometimes it goes back to 750 if I cut it off and go in a store and come back 30 minutes later and crank it up. But after a minute or so it goes back to 950. Maybe that's where it is supposed to idle. Just seems strange. I like it better around 750 to 800
post #4 of 5 (permalink) Old 04-25-2019, 11:48 PM Thread Starter
Also my Kc38r seems to be getting a louder higher pitched sound is that common after running for a few months.
post #5 of 5 (permalink) Old 05-09-2019, 03:14 AM
dmd
Member
dmd's Avatar
Appears like it thinks that the brake isnt being depressed and it is cold.
dmd is offline
Similar Threads
How high should the high side oil pressure be at idle? paramax55 1994-1997 Power Stroke Technical Info 11 11-18-2014 10:26 AM
Run a little and Die a little Hollywood691 7.3L Power Stroke Technical Info 21 04-20-2013 02:41 PM
Truck still heating up a little high. drwoodchopper 1994-1997 OBS Power Stroke - Aftermarket & Performance 17 07-16-2010 11:00 PM
Newer to the nation sayin high and lookin for a little advise darklcdfeller New To The Nation 6 02-07-2010 03:37 PM
A little rough a little smoke a little weird. doubledoor 7.3L Power Stroke Technical Info 7 10-14-2009 08:15 PM
