Manual Transmission shifting problems - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 4 (permalink) Old 03-12-2019, 02:18 PM Thread Starter
I need to know what this part is it is being fed from the mechanical vacuum pump and has a metal brake line that comes off of the brake master cylinder it also has something to do with the clutch
File Type: jpeg 4893F5F8-66A6-4235-8CE4-4045B5BFAEE6_1552400256968.jpeg (940.1 KB, 57 views)
File Type: jpeg 4B185F3C-E5EC-415B-BF1E-0EC813D4ADB0_1552400270965.jpeg (676.1 KB, 41 views)
duhrmacher is offline
post #2 of 4 (permalink) Old 03-12-2019, 03:11 PM
Moderator
Sbluke55's Avatar
Re: Manual Transmission shifting problems
So what year truck. I'm guessing 94.5-97. I have no idea what that part is. @masakimm do you know.
My guess is it's not related and you have bad bushings in the pedal box.
01 f-250, Standard
Sbluke55 is offline
post #3 of 4 (permalink) Old 03-12-2019, 03:23 PM
Native Texan
masakimm's Avatar
Garage
Well if it has a mechanical vacuum pump it has to be an obs. The only thing I know of over there is the vacuum warning buzzer but it shouldn't have a brake line going to it it should all be vacuum lines. It also should not have anything to do with the clutch. the pictures are hard to tell what exactly it is.
Give it to Mikey. He won't eat it he hates everything. Hey Mikey!! He Likes It.
Upgrades:
masakimm is offline
post #4 of 4 (permalink) Old 03-13-2019, 12:19 AM
don't play well w others
Dustybumpers's Avatar
Clutch master has nothing to do with the brake master
The orange thing with holes in it looks homemade
Like Mikey said, better pictures are needed
Would also be a help to tell what the shifting problems are???????
Charlie
"A common mistake people make when trying to design something completely fool proof, is to underestimate the ingenuity of a complete fool."
Dustybumpers is online now
Similar Threads
Transmission shifting problems kmh Transmission Related 2 02-12-2014 11:53 PM
SCT causing transmission to have problems shifting strokin_black 6.4L Power Stroke - Aftermarket & Performance 12 01-19-2014 05:07 PM
Mercon transmission fluid manual transmission? BIG_RED 1994-1997 Power Stroke Technical Info 25 04-28-2011 12:28 AM
hard shifting manual jdower Transmission Related 0 03-03-2011 12:47 PM
Manual Transmission problems vanderchevy18 Transmission Related 8 08-31-2009 05:36 PM
