I’m doing mild upgrades looking for opinions - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 4 (permalink) Old 03-02-2019, 04:29 AM Thread Starter
Bartholamew's Avatar
I have a 96’ ext 4wd lb with 160k. I mainly tow with it. Fully loaded the trailer is just under 14k. The clutch is done. So I’m going with a Southbend single mass. Wire harness is shot as well as plugs. Figured since I’m there I’ll do injectors. Rosewood 160/30 were recomended. Also doing Diamond eye 4”. It allready has a TS-6 with their canned tunes. Also putting in an edge cs2 for guages. The question I have is What kind of turbo upgrade should I do? I’m not looking to make something that will pull walmart in the low 9’s at a 1/4 mile. In the future i’ll be looking for a intercooler but for now this is what I have time and money for.
Bartholamew is offline
post #2 of 4 (permalink) Old 03-02-2019, 04:45 AM Thread Starter
Forgot I’m adding RiffRaff cold air also.
post #3 of 4 (permalink) Old 04-19-2019, 07:48 PM
Re: I’m doing mild upgrades looking for opinions
Not sure if you made up your mind yet but I would also consider 205/30's. Not that there is anything wrong with the 160s but depending on the condition of your hpop your icp might drop off in the higher tunes. The 205's will not be as oil hungry since it is a hybrid injector. As for the turbo I would recommend KC turbos. I run the 63/73 journal bearing turbo since I am manual. They also have a 66mm version but judging how the 63mm runs I think it would be a little bit laggy on those injectors. If you have the money the ball bearing turbos (tiger turbo, kc38r) are great options as well. I'm not very familiar with the obs fuel systems but switching to e-fuel might be something to consider as well.
2002 F-250 ECSB ZF6
FF 205/30's, KC 300X 63/73 .84, South Bend Clutch, CNC Fab 4 Line Feed, AEM 400LPH, PHP Tuned
02_7.three is offline
post #4 of 4 (permalink) Old 04-19-2019, 08:49 PM
alleged moderator
tjctransport's Avatar
choices and suggestions are good.
but i would dump the canned tunes for custom written tunes.
tom
tjctransport is offline
Similar Threads
Thinking about doing upgrades bdemutis 7.3L Power Stroke - Aftermarket & Performance 9 08-24-2015 05:43 PM
need advise on 4r100 tc and mild upgrades to trans jeremys Transmission Related 8 04-20-2014 12:33 PM
Looking for tire opinions/rim opinions jaygreen80 11-16 6.7L Power Stroke Aftermarket & Performance 1 05-26-2013 02:57 AM
any hints on my upgrades im doing tatertot 6.0L Power Stroke - Aftermarket & Performance 7 04-08-2012 05:45 PM
Looking for a mild all spring lift for an '01 F350 thetonka 1999-2010 Super Duty General Aftermarket 10 10-22-2008 12:10 AM
