Vehicular enhancements advice - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 4 (permalink) Old 01-22-2019, 03:08 PM Thread Starter
I've got an '02 that has the basic initial mods done to it and am now looking to take the truck a bit further. I've read these forums until my eyes were bleeding and have a good idea of what I will do but thought it wouldn't hurt to throw out what I'm thinking and see what the opinions are.
Truck as is:
6637 Donaldson filter
4" MBRP exhaust
Hutch mod
Harpoon mod
DP Tuner (40 tow, 60 tow, 60 daily, 80 daily)
Boost & EGT gauges
Stock trans temp gauge
Leveling kit
Bags in the rear
295 Cooper AT3 XLTs
What I plan to do:
BW 364.5 SXE or 366 SXE with the T4 mount kit (ceramic coated)
160/30 or 180/40 FF injectors
Boots and clamps kit (with new plenums)
Adrenaline or Terminator HPOP
DP Reg Return with bowl delete or Irate IDP standardFS
New tunes (either reflash DP or switch to Hydra)
Sinister upfitter panel for future gauges and switches
The truck does tow (~3000 - 12000 lbs) a couple times a month and regularly has weight (1500lbs) in the bed. It is also one of my DDs and we use it for our vacations (put the camper shell on and load it up). I want the truck to be reliable, strong, and somewhat fun.
And go.....
ascn8 is offline
post #2 of 4 (permalink) Old 01-26-2019, 05:14 PM
2000 F350 SuperDuty 4x4
Calico5's Avatar
Re: Vehicular enhancements advice
Welcome to PSN.
Looks good to me...
I'd do the Hydra tuner (I'm switching to one very soon). Pulling/sending the chip everytime you want to modify tunes is a PIA.
And while you're at it, have them add a "100hp" and/or "140hp" tune to it... ya know, just for fun!
Al in SoCal
AFE Intake; Garrett 38R; Turbine Jacket; Banks IC, BanksBrake
Melling LPOP, External Oil Cooler & Filter System
Stealth 4-line Twin HPOP,
Swamps 160/30's, HVHF IDM; DP-Tuner F5
Full R-R Fuel System, Pre-& Post-pump filtration
Mishimoto Rad & Tank; 4" Exhaust, Twin Aussie Stacks
SouthBend D-D Clutch; ZF 6-spd, GearVendors O/U Drive
Calico5 is offline
post #3 of 4 (permalink) Old 01-28-2019, 04:46 PM
dmd
Member
dmd's Avatar
OK.. good start.. BUT you haven't even mentioned the transmission
- I believe that stock trans temp gauge is not accurate, get a real one
- Get a 6.0 trans cooler
- Get a more aggressive trans valve body or you will kill the clutches
- Think about a new torque converter as the stack one will not like the power
- Make sure to have a tow tune to lower the power and have better shifting to protect the trans
'00 F350 Supercrewzer Lariet, PSD, Auto, 3.73, CC, 4x4, SWB, SRW, 160/30 w/Gearhead Tunes, 38r, S&B CAI, 4-inch turbo back exhaust, Adrenaline HPOP, BTS Trans, in-tank/pre-pump mod, heater/AC mod, Excursion sound panels, Harvest Gold and Black / Packages: Trailer Tow, Camper, Off-Road.
dmd is offline
post #4 of 4 (permalink) Old 01-28-2019, 06:52 PM
Calico5's Avatar
Excellent point.
I always forget most people have auto's...
Al in SoCal
Calico5 is offline
