Zf6 swap questions - PowerStrokeNation : Ford Powerstroke Diesel Forum
 1Likes
post #1 of 58 (permalink) Old 11-18-2018, 01:26 AM Thread Starter
levi7.3rig's Avatar
Zf6 swap questions
Pulled my auto out this morning and ordered a swap kit for a zf6. Iíve done some research and found a great write up on the process but doesnít mention a few things. I noticed the swap kit didnít come with a steering column. Does anyone know if I can just swap out the plastic cover on the column with one out of a manual truck? Or do I need an entire column out of a manual truck? I realize the manual trucks have the key ďlockĒ tab on the columns, Iím not too worried about having that if it isnít necessary. The swap kit also included a pcm, guy said it was out of a 99, didnít know if it was e99 or l99, will it matter in my 01? (truck is chipped and will be retuned). Itís also coming with a wire harness for the zf6, is it plug and play or do I need to splice some wires? If so, what wires? The kit is coming with a front driveline, will I need a rear driveline? Truck is a crew cab long bed. Iím getting a little ahead of myself and Iím excited to start the swap but wanted to get some info before the trans gets here. Help is greatly appreciated, thanks!
levi7.3rig is offline
post #2 of 58 (permalink) Old 11-18-2018, 01:45 AM
Trust me, I got this...
Cummins Junkie's Avatar
Garage
Re: Zf6 swap questions
I have only done one auto/zf6 swap, and from what I remember, you don't need a column, you can just remove the gear stick and the gear indicator on the dash and put a manual column cover on.
E99 trucks have different injectors than l99 I think. Not 100% sure on that.
On the one I did, we did not have access to a harness, so I had to splice 2 wires on the auto harness to get it to turn over. The 2 biggest on the gear range plug. The manual harness might be just plug and play.
You might be able to use the drivelines you got, they would just be stretched out a bit more. Dont jump it.
The trans hump on manuals is way bigger too, so you might want to find one you can graft onto your cab. Or hack it up and grab the sledge.
Shoulda bought a Cummins.
1997 F250 7.3L XLT, 4x4, 5spd, 315K, TS chip, BD Turbo-Thruster II, Donaldson 6637 filter, 4" straight piped dual exit SOLD
1995 F350 CCLB 6.0L WIP
Pain is inevitable. Suffering is optional.
Cummins Junkie is offline
post #3 of 58 (permalink) Old 11-18-2018, 01:49 AM Thread Starter
levi7.3rig's Avatar
Ok thanks
I know the e99ís have different injectors, but I think I was told tuning it will run the ones I have. Not sure though
Donít plan on jumping my dually haha, Iíd be more worried about everything else before the driveshafts.
The swap came with the trans tunnel cut out of the standard truck
post #4 of 58 (permalink) Old 11-18-2018, 02:05 AM Thread Starter
levi7.3rig's Avatar
Is there any way to tell if the pcm is an l99 or e99 based off of the pcm code? Code is DAC2
post #5 of 58 (permalink) Old 11-18-2018, 03:24 AM
Moderator
Sbluke55's Avatar
I just looked it up. I canít tell. But it did say 49 state cold weather.
01 f-250, Standard
Sbluke55 is offline
post #6 of 58 (permalink) Old 11-18-2018, 03:26 AM Thread Starter
levi7.3rig's Avatar
What would that mean?
post #7 of 58 (permalink) Old 11-18-2018, 03:27 AM
Moderator
Sbluke55's Avatar
I believe the zf6 is shorter than the auto. So you will need a longer driveshaft.
Do you have a digital or mechanical odometer.
01 f-250, Standard
Sbluke55 is offline
post #8 of 58 (permalink) Old 11-18-2018, 03:28 AM Thread Starter
levi7.3rig's Avatar
Mechanical odometer
post #9 of 58 (permalink) Old 11-18-2018, 03:30 AM
Moderator
Sbluke55's Avatar
I have no idea. So itís not set up for komifornia.
01 f-250, Standard
Sbluke55 is offline
post #10 of 58 (permalink) Old 11-18-2018, 03:30 AM Thread Starter
levi7.3rig's Avatar
Well thatís good lol, doing some more research on it right now
