02 F350 no brake lights. turn signals work - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 3 (permalink) Old 11-18-2018, 12:16 AM Thread Starter
Checked light bulbs ok fuses in cab ok new brake light switch ok. Going to check grounds at brake lights. Any ideas?
post #2 of 3 (permalink) Old 11-18-2018, 11:24 AM
Moderator
Sbluke55's Avatar
Re: 02 F350 no brake lights. turn signals work
There is a fuse in the under hood fuse box that is for the rear of the truck. I believe it’s 29 or is it 19. I can’t remember.
01 f-250, Standard
Sbluke55 is online now
post #3 of 3 (permalink) Old 11-18-2018, 01:12 PM
alleged moderator
tjctransport's Avatar
the 02 does not have an under hood fuse box.
in cab fuse box brake on off switch fuse is #34, 10 amp fuse.
if fuse is good, first thing to do is turn the 4 way flashers on off a few times, then check for brake lights. if the flashers were used and the switch hangs up the brake lights will not work.
next step is to ensure the brake light switch has power going into it, and power coming out when the pedal is stepped on. if you have power out of the switch, than your next step is to replace the multifunction switch (blinker switch) in the steering column.
tom
tjctransport is offline
