2000 ford f250 7.3l gtp38r upgrade exhaust and intake upgrade 8" lift n 38s - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 13 (permalink) Old 10-31-2018, 03:20 AM Thread Starter
Eddiejones89's Avatar
I recently purchased a new ts chip and I had cleaned everything disconnected the batteries had keys out etc the ts card that came with it had no writing on it whatsoever so I had installed and removed it several times.
I install it and get no start,no wait to start,ses light stays on but I have my old sct x3 tuner which I know should be able to read codes? It says unable to read...unless I can't connect to obd port while chip installed...
I remove chip plug it all bag in and everything works fine? Could the chip be blank?
Eddiejones89 is offline
post #2 of 13 (permalink) Old 10-31-2018, 10:49 AM
Moderator
Sbluke55's Avatar
Re: 2000 ford f250 7.3l gtp38r upgrade exhaust and intake upgrade 8" lift n 38s
Could be chow well did you clean the contacts on the board?
01 f-250, Standard
Sbluke55 is offline
post #3 of 13 (permalink) Old 10-31-2018, 11:10 AM Thread Starter
They're spotless barely showing copper and it is a big fit
post #4 of 13 (permalink) Old 10-31-2018, 11:11 AM Thread Starter
Snug fit sorry
post #5 of 13 (permalink) Old 10-31-2018, 06:40 PM Thread Starter
Also another thing when I remove chip and put scanner on it it has a p0603 I believe (kam)
post #6 of 13 (permalink) Old 10-31-2018, 07:27 PM
Moderator
Sbluke55's Avatar
That's normal. Sounds like the chip is blank. Either try and return it or have it reburned
01 f-250, Standard
Sbluke55 is offline
post #7 of 13 (permalink) Old 10-31-2018, 07:32 PM Thread Starter
I called and talked to a ts csr and he too me that the 1180406 is a programmed chip for stock high idles 50 75 100 140 and the 1180401 is the unburnt that can have tunes installed but I believe they might have me send it back
post #8 of 13 (permalink) Old 10-31-2018, 09:44 PM
Moderator
Sbluke55's Avatar
Send it back and have them test it or reburn it. . You did clean both sides of the pcm right?
01 f-250, Standard
Sbluke55 is offline
post #9 of 13 (permalink) Old 10-31-2018, 10:41 PM Thread Starter
10-4 buddy
post #10 of 13 (permalink) Old 11-02-2018, 10:51 AM Thread Starter
Update: They were pretty quick to get me a new chip they even overnighted it and guess what it works perfect! Now what can I do with the old one they never asked for back?reburn maybe or garbage lol?
