Best Replacement Alternator - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 10 (permalink) Old 10-22-2018, 01:23 PM Thread Starter
The alternator on my '01 just crapped the bed. Anybody recommend a certain aftermarket alternator?
craigeb's psd is offline
post #2 of 10 (permalink) Old 10-22-2018, 01:30 PM
​ DieselDC's Avatar
Re: Best Replacement Alternator
No aftermarket unless you can get it rebuilt locally. The best is the denso version. 200-250 Ebay
—————signature—————
~Don’t overthink something simple~
...:uptight people suck:...
​ DieselDC is offline
post #3 of 10 (permalink) Old 10-22-2018, 01:35 PM Thread Starter
So I'm better off buying a rebuilt motorcraft than a Duralast Gold or something like that?
post #4 of 10 (permalink) Old 10-22-2018, 01:39 PM
​ DieselDC's Avatar
Yes I would do that.
—————signature—————
post #5 of 10 (permalink) Old 10-22-2018, 01:48 PM Thread Starter
okay...thanks @DieselDC!
post #6 of 10 (permalink) Old 10-22-2018, 11:52 PM
sooty
DC power and don't look back...
sooty is offline
post #7 of 10 (permalink) Old 10-23-2018, 12:33 AM
2000 F350 SuperDuty 4x4
Calico5's Avatar
6G "large-frame" design, higher output than "stock". Reman'd in the US:
https://store.alternatorparts.com/82...lternator.aspx
They also have 160 and 200 amp units, however, they would require some other changes/modifications to your system to handle the higher current.
Don't run that "Denso" Jap-$h!t (which is probably assembled in S-E Asia/China anyway) on your !
~Al
Al in SoCal
AFE Intake; Garrett 38R; Turbine Jacket; Banks IC, BanksBrake
Melling LPOP, External Oil Cooler & Filter System
Stealth 4-line Twin HPOP,
Swamps 160/30's, HVHF IDM; DP-Tuner F5
Full R-R Fuel System, Pre-& Post-pump filtration
Mishimoto Rad & Tank; 4" Exhaust, Twin Aussie Stacks
SouthBend D-D Clutch; ZF 6-spd, GearVendors O/U Drive
Calico5 is offline
post #8 of 10 (permalink) Old 10-23-2018, 02:17 AM
2000f250's Avatar
I run a autozone gold unit on mine no problem with it. I just get a replacement when it goes bad for free. I am only replaced one in 10 years.
2000f250 is offline
post #9 of 10 (permalink) Old 11-02-2018, 01:11 AM
Calico5's Avatar
Yeah, I've run generators from A-zone. But haven't had the best of luck with them. They work, when they work, but don't seem to work for long. And of course they always fail at the most opportune time! (NOT)
Original factory Gen lasted about 9 years. Since then I've been through three A-zone "Gold" generators, all replaced under warranty. The most recent one (on the truck now) was supposedly a "brand new" unit, not reman'd, but was "hecho en China".
Sooo... I'm going to pull it before this winter and replace it with one of the 160-amp units from the company cited above (and increase the conductor size from Gen to Batteries).
Al in SoCal
Calico5 is offline
post #10 of 10 (permalink) Old 11-02-2018, 11:51 AM
alleged moderator
tjctransport's Avatar
i have a local shop rebuild my units.
in 45 years of dealing with them, i have only had one unit need replacing, the starter for my 02 diesel........because it was a new unit and not one of his rebuilds. he warrantied it and built it properly. the alternator and starter in the 88 are 28 years old with 400,000 miles on it, the alternator in the 02 is 250+ amps custom build and 11 years old.
starters and alternators in the 79's are all over 25 years old and still work fine.
auto parts parts are a crap shoot. the rebuilders replace what is bad and call it rebuilt.
tom
tjctransport is offline
