Desperately seeking Joey Terminator Engineering. - PowerStrokeNation : Ford Powerstroke Diesel Forum
 16Likes
post #1 of 40 (permalink) Old 10-15-2018, 10:59 PM Thread Starter
FlatRateTech
I am attempting to get in touch with Joey about a T500 purchased from diesel power products.com
today I spoke with a rep cant remember his name but basically he represented that they no longer sell the T500 and offered to sell me a pump from a different company.
The issue here is that the T500 never generated enough oil pressure to start the truck.
I did move on to other projects for a time, but started back in OCD mode determined to get this thing running.
So, what happened was that I sent in my core unit, which was to be rebuilt and sent back to me.
I received the unit, but it leaked, so sent it back and Joey said it was fine.
Believing that the no start condition must be some other issue so far not discovered, I began a long and expensive journey into everything from injectors and injector sleeves, PCM, IDM, wiring harness, turbo, even checked the compression to be sure that it was not just a worn out engine.
Anyway, learned a lot, took a long time, spent a lot of money…
Finally after breaking out Occam's razor#I realized that the only answer had to be that the T500 was not generating enough oil pressure.
Well I had to be sure, because honestly I was getting tired of chasing ghosts on this no start truck and one thing I have learned is that replacing parts is not the way to go.
The best thing to do is to test out the issue, prove it, then once you have a verifiable test, you can take care of business.
So, first thing, need a high pressure liquid filled gauge, but you also need a length of hose that is capable of containing high pressure hydraulic fluid in this case oil but you will also need to cap or block off one end of the HPOP so you can test out not only each individual head, but also to test just the pump itself to see if there is an issue with the pump.
Well, after a good bit of testing and a order to an ebay seller I had the equipment I needed to test out the T500.
So, turns out that the T500 will not generate any more than 156 PSI connected to both heads, 236 to one head or another, (verified that there are no leaks anywhere at all) up to 150 psi, air pressure. which is lighter than oil .
Anyway to make a long story shorter, I have now verified that the T500 purchased through Diesel Power Products.com Was in fact defective, some time did pass, but this pump never started this truck so there are Zero miles on this pump.
I suspect that there is an internal issue, but I am not prepared to take this thing apart, mostly because even if I did manage to get it apart without breaking something I do not have the parts to make a repair.
So, in order to contact Joey, I have to make at least 15 posts here and I understand that but I guess I will have to try to be somewhat diplomatic without intentionally trying to make someone angry, its not my intention I just cant find a way to make contact. Diesel power products, refutes, a warranty, states that there is a high failure rate and cannot contact Joey, thats not me saying that either. . . I am a little irritated that a company would collect 791.00 for a part that never worked and then run down the jobber instead of doing the right thing but hey if they can do that I can do this.
let see how many more posts do I need now.
reelstuff is offline
post #2 of 40 (permalink) Old 10-15-2018, 11:16 PM
​ DieselDC's Avatar
Re: Desperately seeking Joey Terminator Engineering.
Well LtDan on here has a terminator pump as well and it’s trash like yours. He sent it back a few times to no avail.
—————signature—————
~Don’t overthink something simple~
...:uptight people suck:...
BBslider001 and reelstuff like this.
​ DieselDC is offline
post #3 of 40 (permalink) Old 10-15-2018, 11:21 PM
Native Texan
masakimm's Avatar
Garage
yeah joey is impossible to get ahold of anymore. I had a badger pump but company is out of business I bought a adrenaline from diesel site and couldn't be happier other then having my pump fail in under 3500 miles. if the company u bought it from won't contact joey I don't know how u will get ahold of him. I tried and tried before I bought the badger never could get ahold of him.
"Y'all have a wonderful"
"My name is Bob the guy floating in the lake with no arms and no legs"
TSGT Bob W Martin USAF 1948-2014
reelstuff likes this.
Upgrades:
masakimm is offline
post #4 of 40 (permalink) Old 10-15-2018, 11:32 PM
THop's Avatar
Garage
So is this high failure rate with the T500’s a recent thing or are all the T500’s questionable? And the Adrenaline pump crapped out after 3500miles?? So who actually builds a reliable pump? These things are expensive as hell and shouldnt be so unreliable. Also the company making them should stand by there product and at the very least be available to customers who have problems. Hope you get something figured out with the pump. Keep us posted on what happens
97 F350 4x4. 54xxxkm
Reg cab 8' Box
Just starting to pick at it
THop is offline
post #5 of 40 (permalink) Old 10-15-2018, 11:52 PM
Moderator
Sbluke55's Avatar
You can try all you want to get ahold of Joey but he wont get back to you. He hasn't been here for quite a while. Sorry your sol.
01 f-250, Standard
Sbluke55 is online now
post #6 of 40 (permalink) Old 10-16-2018, 12:32 AM
Native Texan
masakimm's Avatar
Garage
no the badge crapped out the adrenaline is what I replaced it with I should have bought the dieselsite pump but tried to save a few hundred and it cost me another pump. It sucks but bite the bullet and contact dieselsite they took really good care of me.
Upgrades:
masakimm is offline
post #7 of 40 (permalink) Old 10-16-2018, 01:20 AM
2000f250's Avatar
Hi I have to second the pump from diesel site. I have had mine for two years and love it plus great customer service.
2000f250 is offline
post #8 of 40 (permalink) Old 10-16-2018, 02:14 AM
79jasper's Avatar
Yup, he no longer deals directly with customers. Probably for good reason....
I do have to ask, how many different iprs did you try?
And I assume checked the gear bolt countless times?
Sent from my SAMSUNG-SM-G930A using Tapatalk
79jasper is online now
post #9 of 40 (permalink) Old 10-16-2018, 12:58 PM Thread Starter
FlatRateTech
yep looks like there is no way to reach the guy.
post #10 of 40 (permalink) Old 10-16-2018, 01:06 PM Thread Starter
FlatRateTech
Two known good IPR tested in running 7.3 powerstroke, so they work and are good, also verified that my engine will run with a good HPOP, ,
The one thing I find fascinating is that there are still so many companies that are promoting this product.
Seems a little dishonest. . .
If you buy this product and something goes wrong, you're screwed.
