3.08:1 gear - PowerStrokeNation : Ford Powerstroke Diesel Forum
 1Likes
  • 1 Post By Calico5
post #1 of 7 (permalink) Old 10-10-2018, 08:20 PM Thread Starter
3.08:1 gear
Anyone have an idea where I can find some 3.08:1 (or close) gears? Please tell me I'm not going to have to swap my axle.
File Type: jpg Screen Shot 2018-10-10 at 4.21.43 PM.jpg (15.8 KB, 23 views)
Johnny_the_menace is offline
post #2 of 7 (permalink) Old 10-10-2018, 08:23 PM
Bugman's Avatar
Re: 3.08:1 gear
Randys Ring And Pinion.
Bugman is offline
post #3 of 7 (permalink) Old 10-10-2018, 08:36 PM
Moderator
Sbluke55's Avatar
Re: 3.08:1 gear
Why 3.08? And which axle?
I just looked on Randy ring and pinion and the smallest ratio is 3.55 which is stock.
01 f-250, Standard
Sbluke55 is offline
post #4 of 7 (permalink) Old 10-10-2018, 08:41 PM Thread Starter
Re: 3.08:1 gear
bc I need more top end. Its a stock 07 F250 axle so sterling 10.5?
post #5 of 7 (permalink) Old 10-11-2018, 12:29 AM
2000 F350 SuperDuty 4x4
Calico5's Avatar
Re: 3.08:1 gear
Get an over-drive...
https://www.gearvendors.com/f2wd4s.html
And why is the attached picture in the first post showing [what appears to be] a Ford fender well with a Cummins engine inside it?
[email protected] likes this.
Al in SoCal
AFE Intake; Garrett 38R; Turbine Jacket; Banks IC, BanksBrake
Melling LPOP, External Oil Cooler & Filter System
Stealth 4-line Twin HPOP,
Swamps 160/30's, HVHF IDM; DP-Tuner F5
Full R-R Fuel System, Pre-& Post-pump filtration
Mishimoto Rad & Tank; 4" Exhaust, Twin Aussie Stacks
SouthBend D-D Clutch; ZF 6-spd, GearVendors O/U Drive
Calico5 is offline
post #6 of 7 (permalink) Old 10-11-2018, 01:35 AM Thread Starter
Re: 3.08:1 gear
Nah, Allison 1000 or 2400. A gear is $300; an Allison swap is $2500. Really just need between 2.41 and 3.08
Im running 6bt and 518.
post #7 of 7 (permalink) Old 10-12-2018, 01:01 PM
m j
m j's Avatar
Re: 3.08:1 gear
2wdr or 4x4? to get that ratio dana made a d61. the sterling it looks like it was available at one time for the short pinions.
not a viable option
1997 F250 rclb 4x4,Comp910s,SRP1.1,Irate T4 s468,FullForce 350/200,efuel A1000 5/8" drawstraw,DI fuel fittings,D60f Detroit,Grizzly10.25,windowed 7.3 Oct 9/14
rebuild .010 riffraff cut pistons,swamps fire ring kit,Girdle,high-filled block,Manley rods,SBC dualdisc,ATI dampner,MorelLifters,MantonPushrods,ColtCam,
m j is offline
