Superduty Engine Harness - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 5 (permalink) Old 10-01-2018, 10:37 PM Thread Starter
Curious if the stock engine harness is available for 99-02 7.3's?
Looking to replace on top of engine and down to PCM/IDM.
Thanks
glovemeister is offline
post #2 of 5 (permalink) Old 10-01-2018, 10:39 PM
alleged moderator
tjctransport's Avatar
Re: Superduty Engine Harness
that is probably going to be a junk yard item only
tom
tjctransport is offline
post #3 of 5 (permalink) Old 10-02-2018, 07:44 AM
Philhan69@aol.com's Avatar
Check this out. If it is in fact the right one.
Sent from my SM-G955U using Tapatalk
post #4 of 5 (permalink) Old 10-04-2018, 07:08 PM
Swamps builds whole new engines that come with all new wiring. Could probably get it from them, or they could at least point you in the right direction.
2000 F-250 4x4 SuperCab Short Bed 7.3 w/ 280,xxx mi - 4" Pro Comp - Redhead - 37x12.50x17 BFG A/T KO - 3.73 Gears - CTS2 - Hydra - FFD 238cc/80%
KC38r 366 - Adrenaline - Irate Fuel System w/ Sump - 4"Exhaust - K&N CAI w/ S&B Filter - FFD Bellowed Up Pipes - AIH Plug - RiffRaff Plenums & Boot Kit
mcnance865 is offline
post #5 of 5 (permalink) Old 10-09-2018, 06:49 PM
brian42's Avatar
Unfortunately that is for a 6.0L.
I don't think that Ford has any more new ones for the 7.3L so you'll have to go a different route (junkyard, Swamps, etc.)
The Money Pit
2003 F-250 7.3L PSD FX4 CCSB, Dual Alternators - 160/80 SS, T500, FRx, 6.0 IC & TC (w/Derale), S&B, RR 4/4 Wheel, EBPV-less, RR OCR, IH Up-Pipes, Hydra (PHP & GH), ISSPRO Gauges, FTVB, 4" MBRP, H&H, Racor PS120, 140A Alternators, North Stars, Dynatrac, XRF, ATS Springs
brian42 is offline
