EGT's while towing. - PowerStrokeNation : Ford Powerstroke Diesel Forum
 1Likes
  • 1 Post By CSIPSD
post #1 of 5 (permalink) Old 09-16-2018, 09:27 PM Thread Starter
Scoobert's Avatar
EGT's while towing.
Total noob question here.
I just put in my isspro pyro gauge last week (on driver side manifold) and while idling the temps run around 300 which seems about normal and conformed with a digital temp gauge.
Pulled my 9800 lb fifth wheel this weekend
Cruise locked at 70 mph, 9.8 lbs boost, 2350 rpm = 950-1050 egt, is this within a normal range?
I ask because I just got a hydra to install and am afraid it will be running much hotter when I add more power.
Thanks guys
My setup
2000 f350 C&C 2WD DRW 4.10 gears
Automatic w/ trucool 40K
stock injectors
4" turbo back straight pipe
RR 6637 intake
Scoobert is offline
post #2 of 5 (permalink) Old 09-16-2018, 10:29 PM
KIB7.3's Avatar
Garage
Re: EGT's while towing.
Anything below 1100 is usually ok.
XLT CCSB, 4x4, 3" Downpipe, 4" Exhaust (with CAT delete), 140V IDM Mod, TS6 Position Chip, K&N, Transmission built by State to state transmission in AZ
KIB7.3 is offline
post #3 of 5 (permalink) Old 09-16-2018, 10:39 PM
alleged moderator
tjctransport's Avatar
^^^ agreed^^^
you can't really go by idle, you want normal cruise temp.
at 55 mph with cruise set basically flat ground in central New Jersey, i see around 600 degrees.
pulling hills i can easily hit 1200+ degrees in 80 econo tune
tom
tjctransport is offline
post #4 of 5 (permalink) Old 09-17-2018, 09:18 AM
Philhan69@aol.com's Avatar
I see the same temps on my as you have . I can hit 1100 empty pulling a big grade until I let out of it. On a big grade pulling I see 1200 for a second then i let out of the throttle. I'm also running a hydra and I love it along with a kc38r.
Sent from my SM-G955U using Tapatalk
post #5 of 5 (permalink) Old 11-07-2018, 09:18 PM
<<< THE GAUGE WHORE...
CSIPSD's Avatar
International says 1250* sustained...
Anything below 1250* is fine. Can tow all day at 1250*.
MwR likes this.
Joe
CSIPSD is offline
