High Voltage IDM on Early '99 stock injectors - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 3 (permalink) Old 09-06-2018, 12:29 AM Thread Starter
Most of us are familiar with the High Voltage resistor mod for the 7.3 IDM. I did the mod myself recently and did notice improved throttle response. Today I found an aftermarket supplier for IDM's and they have options for upping the voltage from 110v to 150v. What puzzled me was the notation that anything above 120v requires performance injectors. Why do you think this is? For what it's worth, they do have a great price on reman IDM's for $129.
The company is allcomputerresources.com
lotekinc is offline
post #2 of 3 (permalink) Old 09-06-2018, 09:58 AM
Philhan69@aol.com's Avatar
Re: High Voltage IDM on Early '99 stock injectors
I just replaced my idm with one from the same company. It works great. No problems.
Sent from my SM-G955U using Tapatalk
post #3 of 3 (permalink) Old 09-06-2018, 01:51 PM
It might just be that you won't gain any extra benefit after a certain voltage unless you are using bigger performance injectors. Read up on Swamp's HVHF IDM. It is 140v I think, but also a higher frequency so it can "send the signal to the injectors" more times in a given period.
2000 F-250 4x4 SuperCab Short Bed 7.3 w/ 280,xxx mi - 4" Pro Comp - Redhead - 37x12.50x17 BFG A/T KO - 3.73 Gears - CTS2 - Hydra - FFD 238cc/80%
KC38r 366 - Adrenaline - Irate Fuel System w/ Sump - 4"Exhaust - K&N CAI w/ S&B Filter - FFD Bellowed Up Pipes - AIH Plug - RiffRaff Plenums & Boot Kit
mcnance865 is offline
