3.5 Inch Down-pipe - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 13 (permalink) Old 08-25-2018, 10:28 PM Thread Starter
3.5 Inch Down-pipe
I recently removed the stock muffler and put on a straight through magnaflow, but otherwise the exhaust is stock. Is it worth my effort to put on a 3.5 inch down-pipe and if so, who sells one? I know a 4" exhaust would be the best, but I don't want to spend that much and I also don't want to lose much on the bottom end. Also, I'm trying to cut down my egt's a bit, while keeping it relatively cheap and quiet. Currently I have stock tuning, but might add in a mild tow or economy tune....Keeping the focus on a daily driver and towing
escout is offline
post #2 of 13 (permalink) Old 08-25-2018, 10:48 PM
alleged moderator
tjctransport's Avatar
Re: 3.5 Inch Down-pipe
if i remember correctly, the stock downpipe is already 3.5 inches.
tom
tjctransport is offline
post #3 of 13 (permalink) Old 08-25-2018, 11:30 PM Thread Starter
I went out ant measured it at the turbo, as well as on the underside of the truck where it meets the rest of the piping, and it's definitely a 3" down-pipe that meets 3.5" pipe the rest of the way out.
escout is offline
post #4 of 13 (permalink) Old 08-26-2018, 06:42 AM
Stock exhaust is a 3" downpipe to a 3.5" dp back exhaust. I'm not sure how much your budget actually is, but I am guessing if you had not bought the magnaflow muffer, then you could've spent about the same and got a Diamond Eye full 4" exhaust for around $400.
2000 F-250 4x4 SuperCab Short Bed 7.3 w/ 280,xxx mi - 4" Pro Comp - Redhead - 37x12.50x17 BFG A/T KO - 3.73 Gears - CTS2 - Hydra - FFD 238cc/80%
KC38r 366 - Adrenaline - Irate Fuel System w/ Sump - 4"Exhaust - K&N CAI w/ S&B Filter - FFD Bellowed Up Pipes - AIH Plug - RiffRaff Plenums & Boot Kit
mcnance865 is offline
post #5 of 13 (permalink) Old 08-27-2018, 12:39 AM Thread Starter
I definitely don't have anywhere near $400 wrapped up in a muffler, but I agree, 4" wouldn't be a bad option.....It's just not the way it's gonna happen at this point in time. I'm just curious if anyone has experience running a 3.5" dp and if they have, where did they get it from?
escout is offline
post #6 of 13 (permalink) Old 08-27-2018, 02:13 AM
Scoobert's Avatar
A 4" turbo back exhaust is only like $230.00 on amazon, $250 for a diamond Eye on Riffraff. You might be able to get a 3.5 downpipe for $75 but I think it would be a waste of money verses the 3" pipe.
Also you are not going to lose that much on the bottom end with 4" and the egt's will be better especially when towing.
Scoobert is offline
post #7 of 13 (permalink) Old 08-27-2018, 02:31 AM
Project Shamu
Lt.Dan's Avatar
4" downpipe on RiffRaff is $71 right now. Can't beat that. I don't think you'll loose bottom end, even with stock tuning, it should just drop EGT's.
Diamond Eye 4" Aluminized Downpipe
1996 Cali F350 CCFB, 7.3 PSD, 2wd SAS, w/ 378,000 miles.
New Motor at 352,000, DieselSite Legendary Trans at 356,000 and many more
1983 F150 SCSB Flareside, 302 w/ AOD Trans
2002 F450 SCFB, 7.3 PSD 2wd w/ 144,000 miles
SOLD
Lt.Dan is offline
post #8 of 13 (permalink) Old 08-27-2018, 01:37 PM
That's even better pricing than I realized.
OP: what I meant was that with purchasing the muffler and then also buying a downpipe and related hardware, etc., then you would have been close to just buying a whole 4" system. You might be saving a hundered or so dollars now, but if you still end up with a 4" system, then you are paying even more. Not saying this will happen to you, but we see it a lot when people are trying to do upgrades. The ol' "Buy Once. Cry Once" philosophy.
post #9 of 13 (permalink) Old 08-27-2018, 03:27 PM
I'm looking at doing the same thing, a 3.5" down pipe on my 2000 F250 farm truck when I fix some valley oil leaks. The best thing I've found so far is the Magnaflow stainless 3.5" down pipe assy. #15459 for $118 on several sites. Diamond Eye makes an aluminized version but the rest of my exhaust is in good shape and will probably out last it. I pulled the stock muffler and installed an 4" Aeroturbine muffler so when the rest of the exhaust is gone I can transfer it to a new 4" system. The Magnaflow down pipe is mandrel bent and 1/2" bigger so it should help the turbo spool a bit easier with lower EGT and not get in the way of moderate power increases done by compressor wheels and daily/tow tunes. Anyway that's my theory, we'll see how it works out a little later this year.
Lewis19 is offline
post #10 of 13 (permalink) Old 08-28-2018, 02:28 AM
Project Shamu
Lt.Dan's Avatar
Hell OBS trucks can only fit a 3" downpipe and they work just fine, several guys running 600+hp with them. Might as well just leave your 3" in there.
SOLD
Lt.Dan is offline
