Tuner ? chip for 7.3 - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 13 (permalink) Old 08-24-2018, 05:15 PM Thread Starter
Question Tuner ? chip for 7.3
I have a 1999 F350 7.3 214000 miles. It has cold air and 4" exhaust 373 gears 4X4.
I am looking to improve MPG. I have been looking at the Edge Juice with attitude ($849.00), or Gearhead ($500) custom build.
There are a bunch more to chose from. I would like Ideas as to what (CHIP) system to use. Also with the millage I guess I should prepare for injectors some day. I don't no the best way to go for them.
rndyhrn is offline
post #2 of 13 (permalink) Old 08-24-2018, 05:20 PM
Philhan69@aol.com's Avatar
Re: Tuner ? chip for 7.3
Php hydra
Sent from my SM-G955U using Tapatalk
post #3 of 13 (permalink) Old 08-24-2018, 05:22 PM
levi7.3rig's Avatar
Iím running a hydra with gearhead tunes. Most guys are getting away from the ts6 platform and switching to hydra, so when you do injectors, you might have a hard time finding someone to reburn the ts6.
levi7.3rig is offline
post #4 of 13 (permalink) Old 08-24-2018, 05:33 PM
PSN intsigator
heavydoc's Avatar
I have hydra in 2 of mine and soon to be in the 3rd also.
96 F350 rclb drw 2wd psd (built not bought)
01 Excursion Limited 4wd psd (the wifes ride)
02 F350 cclb drw 4wd psd (the land yacht)
heavydoc is offline
post #5 of 13 (permalink) Old 08-24-2018, 06:46 PM
Native Texan
masakimm's Avatar
Garage
If u are looking for a monitor also check out Dp-tuner infinity tuners.
Upgrades:
masakimm is online now
post #6 of 13 (permalink) Old 08-24-2018, 08:28 PM Thread Starter
WOW so many fast responses. THANK YOU VERY MUCH.
I looked into the Hydra and the DP both seam to do what the edge offers for less money.
I will continue my search now.
rndyhrn is offline
post #7 of 13 (permalink) Old 08-24-2018, 09:33 PM
alleged moderator
tjctransport's Avatar
they also will not blow up the trans like an edge does.
tom
tjctransport is offline
post #8 of 13 (permalink) Old 08-26-2018, 06:39 AM
Hydra is the best bet. Edge is a dinosaur as far as tuning for the 7.3. Mainly trans issues. You can get a Hydra now for $325 from most suppliers and that comes with the full library of PHP tunes for stock injectors. If you do upgrades in the future, then custom tunes are just an email away. No down time. Get tunes from many different tuners. 1023, PHP, Gearhead, Jelibuilt, SDK, KC, Swamps, etc.
Edge: stuck with the crappy canned tunes forever. No custom tunes available.
DP: will get good custom tunes. However, you are stuck with DP only.
2000 F-250 4x4 SuperCab Short Bed 7.3 w/ 280,xxx mi - 4" Pro Comp - Redhead - 37x12.50x17 BFG A/T KO - 3.73 Gears - CTS2 - Hydra - FFD 238cc/80%
KC38r 366 - Adrenaline - Irate Fuel System w/ Sump - 4"Exhaust - K&N CAI w/ S&B Filter - FFD Bellowed Up Pipes - AIH Plug - RiffRaff Plenums & Boot Kit
mcnance865 is offline
post #9 of 13 (permalink) Old 08-28-2018, 08:24 PM Thread Starter
Thanks everyone. I have finished looking in to this. I have decided to go with Hydra.
rndyhrn is offline
post #10 of 13 (permalink) Old 11-07-2018, 08:46 AM
SO How did the Hydra work out for you? what kinda increase in MPG did you receive? TIA
Chris Holder is offline
