7.3 hydra tuner - PowerStrokeNation : Ford Powerstroke Diesel Forum
 5Likes
post #1 of 18 (permalink) Old 08-16-2018, 06:11 PM Thread Starter
Tqf
7.3 hydra tuner
Do I have to program my hydra tuner for my 7.3 on a computer before hooking it up ??
Tqf is offline
post #2 of 18 (permalink) Old 08-16-2018, 06:12 PM
Philhan69@aol.com's Avatar
Re: 7.3 hydra tuner
Yes.
Sent from my SM-G955U using Tapatalk
post #3 of 18 (permalink) Old 08-16-2018, 06:13 PM
Re: 7.3 hydra tuner
If it is new and has never had tunes on it then yes. It comes blank.
post #4 of 18 (permalink) Old 08-16-2018, 06:17 PM Thread Starter
Tqf
Re: 7.3 hydra tuner
Okay thank you man just bought it and couldn't get at it to work appreciate it
Tqf is offline
post #5 of 18 (permalink) Old 08-16-2018, 06:50 PM
Re: 7.3 hydra tuner
No problem. I love my hydra.
post #6 of 18 (permalink) Old 08-16-2018, 09:48 PM
Moderator
Sbluke55's Avatar
Re: 7.3 hydra tuner
Just a tip. You need to go to tools and then click on box/hex conversion. Put in your code for your computer and it will tell you what tunes to use.
[email protected] likes this.
01 f-250, Standard
Sbluke55 is offline
post #7 of 18 (permalink) Old 08-17-2018, 01:45 PM
Re: 7.3 hydra tuner
You do not have to load tunes on it before hooking it up. If you install the USB adapter (which is the main advantage of the hydra in the first place), then you can load the tunes after it is installed. Truck will not start until the tunes are loaded however.
2000 F-250 4x4 SuperCab Short Bed 7.3 w/ 280,xxx mi - 4" Pro Comp - Redhead - 37x12.50x17 BFG A/T KO - 3.73 Gears - CTS2 - Hydra - FFD 238cc/80%
KC38r 366 - Adrenaline - Irate Fuel System w/ Sump - 4"Exhaust - K&N CAI w/ S&B Filter - FFD Bellowed Up Pipes - AIH Plug - RiffRaff Plenums & Boot Kit
mcnance865 is offline
post #8 of 18 (permalink) Old 08-27-2018, 06:17 PM
brian42's Avatar
Re: 7.3 hydra tuner
If you put the Hydra in the "0" position it will default to the PCM program/tune.
The Money Pit
2003 F-250 7.3L PSD FX4 CCSB, Dual Alternators - 160/80 SS, T500, FRx, 6.0 IC & TC (w/Derale), S&B, RR 4/4 Wheel, EBPV-less, RR OCR, IH Up-Pipes, Hydra (PHP & GH), ISSPRO Gauges, FTVB, 4" MBRP, H&H, Racor PS120, 140A Alternators, North Stars, Dynatrac, XRF, ATS Springs
brian42 is offline
post #9 of 18 (permalink) Old 08-28-2018, 07:22 AM
Re: 7.3 hydra tuner
#1 position is stock default setting on mine.
post #10 of 18 (permalink) Old 08-28-2018, 01:20 PM
79jasper's Avatar
Re: 7.3 hydra tuner
Yeah, but you don't have to do that. You don't need to put "stock" as a setting, because its built into 00, just like ns is no start.
Sent from my SAMSUNG-SM-G930A using Tapatalk
79jasper is offline
