7.3 van turbo swap - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 6 (permalink) Old 08-12-2018, 03:09 AM Thread Starter
7.3 van turbo swap
Hey guys I just got a early 1999 f550 and I was wondering if I could take the exhaust housing off my 1999 e350 parts van and put it on the trucks turbo or what would I need to swap the van turbo onto the truck.
99E350 is offline
post #2 of 6 (permalink) Old 08-12-2018, 12:46 PM
Moderator
Sbluke55's Avatar
Re: 7.3 van turbo swap
Depends on if either of them are a e99 or not. Do both motors have 3" plenums? If so you just need to buy a van outlet adpator from riff raff
01 f-250, Standard
Sbluke55 is offline
post #3 of 6 (permalink) Old 08-12-2018, 02:36 PM Thread Starter
Yes the e350 is a late 99 but I was planning to swap all the mods off of it and put them on my truck because the van has 500,000 miles and still running strong. But I have a late 99 truck spyder and 3” billet plenum do I need to swap up pipes and all
99E350 is offline
post #4 of 6 (permalink) Old 08-12-2018, 03:19 PM
Moderator
Sbluke55's Avatar
You will need to swap up pipes and the driver's side exhaust manifold. I personally would just buy new bellowed up pipes. Oh and you have to use the Van's turbo pedestal.
01 f-250, Standard
Sbluke55 is offline
post #5 of 6 (permalink) Old 08-12-2018, 09:19 PM Thread Starter
Ok so why would I have to swap the exhaust manifold too? But if I get new up pipes and use the van turbo and pedestal would I still need the adapter if I just use the ebpv assembly?and would that turbo hook straight up to the 3” plenum.
99E350 is offline
post #6 of 6 (permalink) Old 08-12-2018, 09:29 PM Thread Starter
Or what if I just use the van down pipe? And by 3” plenums you mean the things the cold side charge pipe connects to right? Will the stock e99 spyder hook up to the late 99 van turbo though?
99E350 is offline
