Rear suspension mods - PowerStrokeNation : Ford Powerstroke Diesel Forum
 2Likes
  • 1 Post By ​ DieselDC
  • 1 Post By SCstroker
post #1 of 5 (permalink) Old 07-21-2018, 07:08 PM Thread Starter
levi7.3rig's Avatar
Hey guys! So I have a 2001 f350 CCLB DRW, that’s a welding rig and pulls some trailers around. I already leveled the front and when I put my welder and bottles in the bed, it sagged a bit. I’m looking into getting either airbags with an on board compressor or putting timbrens (https://www.suspensionconnection.com...d-support.html) on the rear. My problem is, I know eventually bags will need replaced, compared to timbrens that are just heavy duty bump stops. I’m looking to eliminate the sagging in the rear to make the truck leveled even when my welder is in the bed. So, has anyone ran timbrens on their trucks? Or have advice on which route to go? Thanks!
levi7.3rig is offline
post #2 of 5 (permalink) Old 07-21-2018, 08:17 PM
​ DieselDC's Avatar
Re: Rear suspension mods
Trucks are designed to sag with weight - that’s why the fronts are always lower than the rears. My fronts are 3” from tire to fender while the rear ones are 5”. 1500-2000 lbs and it levels itself out.
Your only option would be some nice heavy duty bags in the rear. Hooked up to an auto air filler deal.
This is a kit I have saved for when I wanna go bags
Check them out.
—————signature—————
~Don’t overthink something simple~
...:uptight people suck:...
levi7.3rig likes this.
​ DieselDC is offline
post #3 of 5 (permalink) Old 07-21-2018, 10:41 PM
79jasper's Avatar
In a longer amount of time than you think... especially if taken care of..
79jasper is offline
post #4 of 5 (permalink) Old 07-21-2018, 10:46 PM Thread Starter
levi7.3rig's Avatar
I was kinda looking more towards bags anyways, I like being able to control the rear end more than just bump stops. I am running pretty wide tires on the stock rims so I don’t have the required 8” ( have about 7”) from tire to frame that the kit dc linked says it needs. I’ve had my eye on the firestone ride rite kit for awhile now, along with the on board compressor but I don’t like the price tag much lol, thanks for the input guys
post #5 of 5 (permalink) Old 08-04-2018, 06:44 PM
SCstroker
I put a set of SumoSprings on my truck. Worked like a charm. I load a golf cart in my bed and then hook up to my camper.
2001 Ford F-250 CC SB
Recon Gauges
Voliant CIB
4"TB MBRP
51 Gallon Titan Tank
SCstroker is offline
