02 F250 SD 7.3 turbo help - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 5 (permalink) Old 07-14-2018, 01:02 AM Thread Starter
So I have to swap out my turbo and pedestal, noise and oil leak, I am leaning toward the KC38r drop in with EBPV delete. Do I need to replace the up pipes? Also want to add a cold air intake. Will I need to upgrade the exhaust as well? Last question what is the difference between stages 1,2,and 3 on the turbos? I have seen some labeled and some not, want to make sure I知 looking for correct one. Thanks
ccranford is offline
post #2 of 5 (permalink) Old 07-14-2018, 02:49 AM
​ DieselDC's Avatar
Re: 02 F250 SD 7.3 turbo help
Kcturbo is the chit. You値l love it. Love mine but I rebuilt my turbo and I知 just as happy. Kc has 1 and 2 for our setup. If you plan to live above 30psi all the time, buy the stg2. If you池e stock or have mild upgraded injectors, stick with stg1.
It will leak now or a little later. If in good shape, run with it till it does leak or if you have the cash, replace them with bellowed up Pipes.
覧覧耀ignature覧覧
~Don稚 overthink something simple~
...:uptight people suck:...
​ DieselDC is offline
post #3 of 5 (permalink) Old 07-14-2018, 11:49 AM
Moderator
Sbluke55's Avatar
Yep replace the up pipes. The dorman ones are fine for around $100 on Amazon.
https://kcturbos.net/collections/7-3...3-stage2-turbo
01 f-250, Standard
Sbluke55 is offline
post #4 of 5 (permalink) Old 08-18-2018, 02:41 PM
Philhan69@aol.com's Avatar
I love my kc38r stage 2.
Sent from my SM-G955U using Tapatalk
post #5 of 5 (permalink) Old 08-18-2018, 02:55 PM
410customs's Avatar
DO the up pipes!!!!
The factory donuts are not good!
I messed around with replacing the factory gaskets a few times before I finally got the up pipes (OBS pipes are $400+, SD pipes are $99, you = lucky)
With that turbo I would consider bellowed up pipes a MUST HAVE
2001 Excursion 7.3, auto, 4x4, 3.73, collecting parts for suspension lift
2000 E350 7.3, auto 2wd, 3.73, toy hauler camper conversion...researching 4x conversion
21.9 liter family
410customs is offline
