ADRENALINE STAGE 2 HPOP - PowerStrokeNation : Ford Powerstroke Diesel Forum
 3Likes
post #1 of 15 (permalink) Old 06-26-2018, 01:22 PM Thread Starter
7.3_powerjokester's Avatar
IS ANY ONE ELSE RUNNING THE ADRENALINE STAGE 2 PUMP IF SO I COULD USE SOME ADVICE I RECENTLY WENT THROUGH AND CHANGED OUT ALMOST EVERY THING I HAVE THE PUMP BIGGER LINES FEEDING THE HEADS NEW ICP, IPR, CPS, IDM, PCM, BUT MY ICP KEEPS FAILING I'VE TIRED DOORMAN, B&W, MOTOR CRAFT ALL SEEM TO KEEP FAILING UNDER THE PSI. IS THERE AN UPGRADE I CAN DO OR SOME KIND OF BYPASS?
7.3_powerjokester is offline
post #2 of 15 (permalink) Old 06-26-2018, 01:29 PM
​ DieselDC's Avatar
Somethings wrong with your system. That’s a lot of parts thrown at it. Idm - new used good known part?
Trying another icp probably won’t he’ll as you have an underlying problem either in the quality of supply to the icp sensor or something is shorting while in operation..
Btw: I didn’t know there were stages of the adrenaline pump. I have one. I also have the cncfab stg2. Both honesty a waste of money if you’re not making power but awesome with some big injectors!
—————signature—————
~Don’t overthink something simple~
...:uptight people suck:...
​ DieselDC is offline
post #3 of 15 (permalink) Old 06-26-2018, 01:56 PM
Moderator
Sbluke55's Avatar
Re: ADRENALINE STAGE 2 HPOP
What's your ipr% when it falls off?
I would check your oil pressure at the hpop res when it falls off. You can have the best pump in the world but without proper supply it won't do crap.
01 f-250, Standard
Sbluke55 is offline
post #4 of 15 (permalink) Old 06-26-2018, 10:10 PM
[QUOTE=​
Btw: I didn’t know there were stages of the adrenaline pump. I have one. I also have the cncfab stg2. Both honesty a waste of money if you’re not making power but awesome with some big injectors![/QUOTE]
I am pretty sure Bob at Dieselsite explicitly says that there is only one Adrenaline and that they are all created the same and equal.
Mine never even thinks about not holding up. It will stay about 3,100 icp. I haven't held WOT more than about 4 or 5 seconds because I am going to fast at that point, but so far no complaints (had it about 4 months)
Sorry for the derail...
2000 F-250 4x4 SuperCab Short Bed 7.3 w/ 280,xxx mi - 4" Pro Comp - Redhead - 37x12.50x17 BFG A/T KO - 3.73 Gears - CTS2 - Hydra - FFD 238cc/80%
KC38r 366 - Adrenaline - Irate Fuel System w/ Sump - 4"Exhaust - K&N CAI w/ S&B Filter - FFD Bellowed Up Pipes - AIH Plug - RiffRaff Plenums & Boot Kit
mcnance865 is offline
post #5 of 15 (permalink) Old 06-27-2018, 01:17 PM Thread Starter
I LOVE THE PUMP IVE HAD IT BUILD 3400 PSI AT 40% IPR DC CREATES SO MUCH POWER THE IDM WAS NEW IN THE BOX THE PCM WAS A REBUILT THE SENSOR WILL LAST A COUPLE OF MONTHS THE START TO LEAK OIL THROUGH THE PLUG CAUSING BAD READINGS AND IT TO THROUGH A CODE
post #6 of 15 (permalink) Old 06-27-2018, 02:13 PM
Moderator
Sbluke55's Avatar
Ah I get it now. You are over pressurizing the system and blowing out the icp’s.
Are you running any tunes? If not you need to. If so you need a revision and ask for lower icp.
​ DieselDC likes this.
01 f-250, Standard
Sbluke55 is offline
post #7 of 15 (permalink) Old 06-27-2018, 02:25 PM
Jennifer@Dieselsite's Avatar
Definitely cap that ICP at 3200.
Sbluke55 and ​ DieselDC like this.
post #8 of 15 (permalink) Old 06-28-2018, 01:52 PM Thread Starter
whats the best place to get custom tunes done?
post #9 of 15 (permalink) Old 06-28-2018, 03:27 PM
​ DieselDC's Avatar
Gearhead, php, sdk
I like php personally.
—————signature—————
post #10 of 15 (permalink) Old 06-28-2018, 04:00 PM
Moderator
Sbluke55's Avatar
Buy the php hydra and have custom tunes put on it. I like SDK, there is also 1023
01 f-250, Standard
Sbluke55 is offline
