Cts2 won’t power up - PowerStrokeNation : Ford Powerstroke Diesel Forum
 1Likes
post #1 of 19 (permalink) Old 06-06-2018, 11:47 PM Thread Starter
levi7.3rig's Avatar
Cts2 won’t power up
Hey guys, just got my cts2 in the mail, decided I’d plug it in and see what happens. Plug it into the obd2 on my 01 f350, no power, plug it into my computer via usb cable, powers up instantly and goes into demo mode. I checked the fuses under the dash and all are good. Any ideas? I’m not running they’re tunes if that has anything to do with it
levi7.3rig is offline
post #2 of 19 (permalink) Old 06-06-2018, 11:52 PM
Re: Cts2 won’t power up
Do you have a scanner you can plug into the obd2 port to make sure something else will power up from it? I had an f150 that did the same thing. Had a tuner on it that worked then I took it in to smog it and they said the computer wont link up. I check the fuses and even tho they looked good I swapped a few out and it ended up working. Either reset something or I had a faulty fuse.
Sent from my SM-G955U using Tapatalk
ben10 is offline
post #3 of 19 (permalink) Old 06-06-2018, 11:53 PM Thread Starter
levi7.3rig's Avatar
I have one but I haven’t tried to use it yet. I can real quick.
post #4 of 19 (permalink) Old 06-06-2018, 11:58 PM Thread Starter
levi7.3rig's Avatar
Cts2 won’t power up
So I tried my usb elm 327, hooked to my computer and it says “no ELM found.”
post #5 of 19 (permalink) Old 06-07-2018, 12:07 AM
Try swapping fuses and wiggling wires then.
ben10 is offline
post #6 of 19 (permalink) Old 06-07-2018, 12:07 AM Thread Starter
levi7.3rig's Avatar
Do you know what fuses to swap? Or all of them?
post #7 of 19 (permalink) Old 06-07-2018, 12:10 AM Thread Starter
levi7.3rig's Avatar
Alright just out of curiosity, tried hooking my computer up to another pickup I have here with the elm 327, still won’t connect.
post #8 of 19 (permalink) Old 06-07-2018, 12:11 AM
​ DieselDC's Avatar
If you plug the elm wireless dongle in, it should light up.
Check the following
—————signature—————
~Don’t overthink something simple~
...:uptight people suck:...
​ DieselDC is offline
post #9 of 19 (permalink) Old 06-07-2018, 12:12 AM
I'm not sure. Honestly. It was a different truck that had the problem. Should be a fuse for ECU, or obd2 port.
ben10 is offline
post #10 of 19 (permalink) Old 06-07-2018, 12:13 AM Thread Starter
levi7.3rig's Avatar
Plug the dongle into the obd2, nothing lights up on either of the trucks I have here (other pickup is an 06 dodge)
