Boost Levels - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 4 (permalink) Old 04-22-2018, 07:10 PM Thread Starter
Dbaker's Avatar
Boost Levels
I have an 02 powerstroke with banks quick turbo assembly and other add ons. I am only showing that I am getting 18psi of boost. Why am I not making more boost? I show 18psi of boost both on gauge that is hooked through the boost fooler and through the OBD port on Torque pro app. I do not hear any leaks on intercooler boots. What are some things that might cause lower boost levels?
Dbaker is offline
post #2 of 4 (permalink) Old 04-22-2018, 07:15 PM
​ DieselDC's Avatar
Re: Boost Levels
Check your ebpv - it could be stuck closed or partially closed and limiting exhaust output and thus low boost. I only produce 20lbs anyways. Iím happy with that.
ďDonít overthink something simple people... ..:sigh:..Ē
​ DieselDC is offline
post #3 of 4 (permalink) Old 05-10-2018, 01:33 AM
shade tree mechanic
dsrace's Avatar
Re: Boost Levels
is your wastegate still have the line on it? if so disconnect it and plug. i put mine on the t bolt clamp. stock inj's cannot over boost it. what rpm are you hitting 18 psi? also what diseldc said.
dsrace is offline
post #4 of 4 (permalink) Old 05-10-2018, 01:35 AM
shade tree mechanic
dsrace's Avatar
Re: Boost Levels
i also took my waste gate controller off and tightened it up 1/4" so it wouldnt open. it was fluttering at 19 psi on mine with the line unhooked. wasnt turbo surge as mine was an e99. its now a sxe366 with no wg.
dsrace is offline
