Making power questions 02 7.3 - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 22 (permalink) Old 04-14-2018, 02:44 AM Thread Starter
Dbaker's Avatar
I am brand new to this forum and have several questions. I have an 02 7.3 2wd and am looking to make about 500hp. I have a banks 4"exhaust with power elbow,banks cold air intake, banks quick turbo assembly (1.0 turbine housing, big head wastegate and compressor wheel), boost fooler and sct X4 programmer. I am wanting new injectors from Full Force and they recommended the stage hybrid's 205/30. I am thinking about getting the turbo rebuild kit with larger compressor housing for a 66/88 compressor wheel. Let me know what everybody thinks in order for me to achieve the 500hp goal. Also what torque converter would you recommend without spending a fortune? Thanks in advance.
Dbaker is offline
post #2 of 22 (permalink) Old 04-16-2018, 02:06 PM
Re: Making power questions 02 7.3
Gonna need more than 205/30s for 500hp to the wheels. It is possible maybe to make that at a peak, but it would not be a usable 500. Also, for that goal will want to look at Fuel System upgrades (RR or full fuel system). Also, I believe you would not want a turbo rebuild kit with just bigger wheels, but would want a full turbo upgrade that way the shafts, bearings, etc. are up to the task and will last. The stock gtp38 was not designed to go anywhere near 500 hp.
I am not sure about a specific torque converter, just that you will want a triple disc.
2000 F-250 4x4 SuperCab Short Bed 7.3 w/ 280,xxx mi - 4" Pro Comp - Redhead - 37x12.50x17 BFG A/T KO - 3.73 Gears - CTS2 - Hydra - FFD 238cc/80%
KC38r 366 - Adrenaline - Irate Fuel System w/ Sump - 4"Exhaust - K&N CAI w/ S&B Filter - FFD Bellowed Up Pipes - AIH Plug - RiffRaff Plenums & Boot Kit
mcnance865 is offline
post #3 of 22 (permalink) Old 04-18-2018, 04:24 AM
​ DieselDC's Avatar
ó- reserved for dude with big balls and lotsa $$$ 500hp daily driver
340cc hybrids (lots of room to grow - cracked block b4 you max out the output of these sticks)
modded H2E 71/19cm
gen3 HPOP
aeromotive big honkin pump
sump in tank--3/4 line to filters--5/8 to itp reg return
DI headers
3.5 downpipe,
4" exhaust out the back
.030 over bottom end studded and girdled,& balanced
crowers rods
cosmetics head gasket
Swamps tuning
BTS backin it up.
ARP head studs 250-4201
ó-end
Now here we go... 160/100 will get you 500 and thatís maxing out the sticks wo no room to grow - find a tuner willing and capable... IIRC
200/200 sticks will get you 550. This is on stock hpop.
Iím running 160/30 with 150hp. It simply kicks ass. Well close to 450 if not some extra. Tears up my tires though
Personally I wouldnít do the above Iím cheap and well versed in what works and what doesnít (at least I think I do but chit Iím a dummy). I would go with (my opinion okay)
200/200 stock fuel stock oil, rebuilt blower w/ ww2, head studs. Better be forged rods. Stg2 slush box with minimum billet input.
Donít overthink something simple people... ..:sigh:..
​ DieselDC is offline
post #4 of 22 (permalink) Old 04-18-2018, 09:45 PM
Oh yea, I didn't even notice OP said it was an '02, which means PMRs. Not gonna be pretty at 500 daily hp...
post #5 of 22 (permalink) Old 04-19-2018, 02:18 AM Thread Starter
Dbaker's Avatar
Awesome guys. Thanks for the input. I have read that the hybrids will get you better power while running stock HPOP and transmission for the most part. I will upgrade the torque converter to start as I do haul a travel trailer. It is about 8k dry weight. I suppose that the 500 hp number is just a number that I have in my head as an attainable goal. I think that if I get the 205/80 or so with an upgraded turbo, I should have a good bit of change in HP numbers. Should be a hell of change from stock. What do you guys think?
Dbaker is offline
post #6 of 22 (permalink) Old 04-19-2018, 11:49 AM
'Cody''s Avatar
If you want hybrids I think the 205/30s you mentioned are a good idea. Pair them with a kc38r or t4 setup and you'll be set. Plenty of power for most, very fun for a daily driver, and should tow rather well depending on turbo and tuning.
I would be suprised if your tranny will hold the power even with a torque converter upgrade but that's ok. They are rebuildable.
Gonna want a regulated return kit. Might think about head studs, push rods, and valve springs. Ask whoever you buy your injectors from what they recommend for supporting mods.
Old Blue, 97' F350, CCLB, 7.3, Auto
Air: SD IC, 3" Plenums
Fuel: E- Fuel, 160/30 Injectors
Turbo: Irate T4, S366
Oil: T500, Melling LPOP
PCM: TW TS, IDM Mod
'Cody' is offline
post #7 of 22 (permalink) Old 04-19-2018, 12:47 PM
​ DieselDC's Avatar
No problem with 500 daily stressing pmr. Tuners have gotten a lot more smarts than we would give them credit far. Have all your supporting chit together and have a tuner tune for them #. Is it recommend vs the stock forged? No, it isnít but it can be done if thatís all that you have.
post #8 of 22 (permalink) Old 04-19-2018, 02:42 PM
​ DieselDC's Avatar
Negative on fuel - stock is fine but good to have if you can afford the rest
post #9 of 22 (permalink) Old 04-19-2018, 06:14 PM
'Cody''s Avatar
I disagree. A regulated return is a good investment even on a stock rig. Add some hybrid injectors that can drop fuel pressure to dangerous levels on the rear cylinders and it becomes a very good investment.
To each his own I guess but if my truck were a super duty it would have a rr kit on it, even with my rather small 160/30s.
https://swampsdiesel.com/products/dr...ed-return-kit/
PCM: TW TS, IDM Mod
'Cody' is offline
post #10 of 22 (permalink) Old 04-19-2018, 07:25 PM
Need advice on hpop replacement. I just air tested the hpop on my 2004 F250 Superduty 6.0L Powerstroke and have a bad pump. I have several questions. Anyone familiar with this ?
RobertnOK is offline
