What gauges - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 8 (permalink) Old 04-04-2018, 02:22 AM Thread Starter
What gauges
Have a 7.3 with manual trans.
Dont know much about diesels. What gauges do i need to have?
I would like to know my exact oil psi than dealing with the stock ford dummy gauge.
Fuel psi?
Turbo psi?
Anything else?
Firefighter6070 is offline
post #2 of 8 (permalink) Old 04-04-2018, 02:35 AM
THop's Avatar
Garage
Re: What gauges
Really its personal preference. But id like to know EGTís and tranny temp plus the ones you mentioned
97 F350 4x4. 54xxxkm
Reg cab 8' Box
Just starting to pick at it
THop is offline
post #3 of 8 (permalink) Old 04-04-2018, 02:45 AM Thread Starter
Originally Posted by THop View Post
Really its personal preference. But id like to know EGT’s and tranny temp plus the ones you mentioned
Do you know a good reasonable gauge set?
Dont think my manual trans temp matters i guess. I know auto does
post #4 of 8 (permalink) Old 04-04-2018, 11:28 AM
Moderator
Sbluke55's Avatar
Re: What gauges
I have isspro gauges. I like them. I have egt, boost, and fuel pressure. If I could do it over again it would be the cts2 with the Comp kit. Yeah itís spendy but you can monitor quite a bit. Like ipr, icp, ebp, oil temp and possibly coolant temp, plus tons more.
01 f-250, Standard
Sbluke55 is offline
post #5 of 8 (permalink) Old 04-04-2018, 10:37 PM
Re: What gauges
Agreed with Sbluke55. The CTS2 comp kit (which I have) is the way to go. I have an actual boost sensor ported into the Y, fuel pressure, and EGT plus everything else the PCM monitors. I have 9 different PIDs displayed on the screen at one time and all are very easy to read and change/customize. I put the adapted pod that mounts on top of the dash and it does not block any field of vision and blends in (the pod is color matched). So much better than having gauges scattered all over between a pillar, steering column, above rear-view mirror, under cup holder, etc.
One spot. Everything I need. Easy. A little expensive, but not when you start adding 4-6 mechanical gauges and associated pods and wiring. Mine has one cord to the screen and then the easy daisy chain style hookups for EGT, Boost, and Fuel Pressure (these just plug into each other; no real "wiring").
2000 F-250 4x4 SuperCab Short Bed 7.3 w/ 280,xxx mi - 4" Pro Comp - Redhead - 37x12.50x17 BFG A/T KO - 3.73 Gears - CTS2 - Hydra - FFD 238cc/80%
KC38r 366 - Adrenaline - Irate Fuel System w/ Sump - 4"Exhaust - K&N CAI w/ S&B Filter - FFD Bellowed Up Pipes - AIH Plug - RiffRaff Plenums & Boot Kit
mcnance865 is offline
post #6 of 8 (permalink) Old 04-05-2018, 01:09 AM Thread Starter
Well i have a bluetooth set up that monitors the PCM deal. FORSCAN is the program.
post #7 of 8 (permalink) Old 05-10-2018, 02:25 AM
shade tree mechanic
dsrace's Avatar
Re: What gauges
the cts2 gauge sounds like a good way to go as long as it doesn't connect to the data link connector unless the sd truck ports don't go to sleep like the obs do. i have a manual trans and i monitor boost, egts, and coolant temp with auto meter gauges ( link posted below). no you do not need to monitor your trans temp even though it has a pump and runs through the oil cooler built into your radiator. fuel psi would be a good thing but i have a port on the fuel filter housing i added i check once and a while. is the dumby guage on the dash oil temp or psi?
https://lmr.com/item/ATM-880077/auto...yABEgKDYvD_BwE
dsrace is offline
post #8 of 8 (permalink) Old 05-10-2018, 02:35 AM
shade tree mechanic
dsrace's Avatar
Re: What gauges
i have two friends running these and they like them.
Power Stroke Necessity: AeroForce Technology Interceptor Gauge - Diesel Power Magazine
dsrace is offline
