Custom hydra tunes - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 12 (permalink) Old 03-27-2018, 09:29 PM Thread Starter
Custom hydra tunes
I’m located in Tulsa Oklahoma. I’m looking for live tuning for my 7.3 I have 180/30% injectors with a 38r. I’m haveing a problem getting the boost I want to run in my 140 tune. So I’m looking for a tuner near me to get a better tune.
Timluce24 is offline
post #2 of 12 (permalink) Old 03-28-2018, 02:35 AM
79jasper's Avatar
Re: Custom hydra tunes
I'm due north of you.
You might try premier truck and trailer out in vinita. I don't know if he does live tuning or not.
79jasper is offline
post #3 of 12 (permalink) Old 03-28-2018, 03:10 PM
Moderator
Sbluke55's Avatar
What issues are you having with your boost?
01 f-250, Standard
Sbluke55 is offline
post #4 of 12 (permalink) Old 03-28-2018, 09:38 PM Thread Starter
After thinking about it I would call it more of a fuel problem then a boost problem if I hit it from a stop there’s not really a lot of smoke. My service engine soon light comes on then goes off after I get out of it and it throws the high boost code from the map. My problem is my egts are only getting to like 1000. But if I’m getting on the highway I can play with it and hit at about 30 and it will throw smoke and then the turbo take off and it will run like a rocket. So i figured it was just the map sensor defueling. I told this to tony wildman and he said he could write the tunes for me where that won’t happen so i bought what he was selling and the extreme tune does not run well on my truck where the street tune runs really well. And now I can’t get ahold of tony to do the changes for the tunes.
post #5 of 12 (permalink) Old 03-29-2018, 11:23 AM
Moderator
Sbluke55's Avatar
First off I would check for boost leaks. Then if that checks out and your sure you have leaks on the up pipes. Crank the waste gate rod in 2-3 turns and see what happens.
01 f-250, Standard
Sbluke55 is offline
post #6 of 12 (permalink) Old 03-29-2018, 01:19 PM Thread Starter
If I had a boost leak wouldn’t I have a problem with high egts I never see mine above 1100
post #7 of 12 (permalink) Old 03-29-2018, 04:10 PM
Moderator
Sbluke55's Avatar
Yeah. I like to just toss that out there before telling people to tighten down the waste gate. Most people just skip that step and go straight to the waste gate.
01 f-250, Standard
Sbluke55 is offline
post #8 of 12 (permalink) Old 03-30-2018, 01:17 PM Thread Starter
I just don’t feel like that would help me if I have no fuel to go with the extra air
post #9 of 12 (permalink) Old 03-31-2018, 02:37 PM
79jasper's Avatar
Could be a weak lift pump.
79jasper is offline
post #10 of 12 (permalink) Old 03-31-2018, 02:44 PM
Moderator
Sbluke55's Avatar
Could be a lot of things. Your really not doing any testing.
The 38r is known for having the waste gate rod loose from the factory.
You need to check fuel pressure under load? Whatís your icp and ipr number under wot? Whatís your injector pulse width? Where are you getting your boost readings? Do you have a boost cooler? Have you checked your boost pressure to the map sensor?
01 f-250, Standard
Sbluke55 is offline
