old vs super duty 7.3 - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 7 (permalink) Old 02-27-2018, 02:20 AM Thread Starter
duxpsd's Avatar
I have a 97 7.3 with efuel, baby swamps, hydra swamps tunes, BHAF, MBRP exhaust and built trans.
New truck 2001 7.3 with hydra and php tunes, BHAF, MBRP exhaust.
I know that my injectors on the newer truck are larger and the turbo is "better". With that said my old truck will blow my 2001 away. Still own the old one but its my sons now. The 2001 seems to be running normal so what could be the hold up???
Im buying parts now to rebuild the 01 turbo and hoping that helps. Would swamps tunes make a difference on a factory injector? Any ideas are appreciated.
Thanks guys!!!!
2001 F250 CCLB, PHP Hydra, 6637, MBRP 4" exhaust and rear air bags
97' F250 ECLB, 7.3, Baby Swamps, Hydra w/swamps tunes, 6637, 3"dp 4" straight, Dana 60, 2.25 PMF RSK, Built Trans & Cooler, DIY efuel
duxpsd is offline
post #2 of 7 (permalink) Old 02-27-2018, 02:46 AM
​ DieselDC's Avatar
Re: old vs super duty 7.3
Baby swamps is what makes your obs faster. Baby swamps far exceeds stock stickers by a margin. Plus you got some goodies to make the tuning better too!
​ DieselDC is offline
post #3 of 7 (permalink) Old 02-27-2018, 03:18 AM
Baby swamps are called 175/146. The 146 is a part number or something for a stock nozzle IIRC. Swamps just uses that terminology to make them sound more special I guess. So you have 175/0 single shot injectors in the OBS and 140/0 split shots in the SD. That split shot action reduces the power making capacity by a few more ccs to do the pilot shot. So you should have more power with the OBS truck for sure.
Also, what is BHAF? Im not familiar with that.
2000 F-250 4x4 SuperCab Short Bed 7.3 w/ 280,xxx mi - 4" Pro Comp - Redhead - 37x12.50x17 BFG A/T KO - 3.73 Gears - CTS2 - Hydra - FFD 238cc/80%
KC38r 366 - Adrenaline - Irate Fuel System w/ Sump - 4"Exhaust - K&N CAI w/ S&B Filter - FFD Bellowed Up Pipes - AIH Plug - RiffRaff Plenums & Boot Kit
mcnance865 is offline
post #4 of 7 (permalink) Old 02-27-2018, 03:26 AM
79jasper's Avatar
Technically the second number is supposed to be nozzle/orifice size in a percentage over stock.
So say a 150/200. The nozzle/orifice would be 200% larger than stock.
But in the case of the baby swamps, I think it's just a number they threw on.
79jasper is offline
post #5 of 7 (permalink) Old 02-27-2018, 03:38 AM
Native Texan
masakimm's Avatar
Garage
I put a set of 160cc in my truck and even with out tuning its amazing the power it has added. even running on stock programing the will out perform stock.
Upgrades:
masakimm is offline
post #6 of 7 (permalink) Old 02-27-2018, 12:07 PM
'Cody''s Avatar
Baby swamps are 150cc.
Old Blue, 97' F350, CCLB, 7.3, Auto
Air: SD IC, 3" Plenums
Fuel: E- Fuel, 160/30 Injectors
Turbo: Irate T4, S366
Oil: T500, Melling LPOP
PCM: TW TS, IDM Mod
'Cody' is offline
post #7 of 7 (permalink) Old 02-27-2018, 11:58 PM
You are correct. I was thinking that the other ones were called "Baby Swamps". I apologize, I was incorrect. But the "146" nozzle is a stock size nozzle or "0%" if following the lingo. So these would be 150/0 single shot injectors.
Sorry for the confusion.
