180/30 injectors - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 14 (permalink) Old 02-25-2018, 03:25 PM Thread Starter
levi7.3rig's Avatar
180/30 injectors
My injectors are going out so I decided it was time to replace, and since Iím going to replace them, I would like to upgrade them. Iím currently looking at 180/30cc full force injectors with gearhead tunes to go with them. Just wanted to see if I should upgrade/replace anything else to support them. Truck already has CAI, exhaust, intake plenums, and up pipes. Was also planning on throwing in a wicked wheel 2 (diesel site giveaway I won a few months back) and an edge monitor for gauges (got rid of my glowshift gauges along with my other pickup) thanks!
levi7.3rig is offline
post #2 of 14 (permalink) Old 02-25-2018, 03:44 PM
​ DieselDC's Avatar
Re: 180/30 injectors
Hpop lines, fuel lines, plenum inserts. Pedestal delete. If staying with the oem turbo, rebuild it and get a ww2. @[email protected] corey will hook you up or shop where itís more convenient for you.
​ DieselDC is offline
post #3 of 14 (permalink) Old 02-25-2018, 03:47 PM Thread Starter
levi7.3rig's Avatar
The ww2 will definitely be going in, itís been sitting in the garage for months now. Donít think Iíve heard of plenum inserts, what are they? And why the pedestal delete?
post #4 of 14 (permalink) Old 02-25-2018, 03:55 PM
​ DieselDC's Avatar
post #5 of 14 (permalink) Old 02-25-2018, 03:58 PM
​ DieselDC's Avatar
Pedestal delete cleans up the valley for potential leaks
Plenum inserts allows you to torque down the boots wo crushing them
post #6 of 14 (permalink) Old 02-25-2018, 04:00 PM Thread Starter
levi7.3rig's Avatar
I knew I forgot something. I am running riff raff boots. But I will look into the inserts. Thanks
post #7 of 14 (permalink) Old 02-26-2018, 12:42 AM
If you have aftermarket intake plenums, I'm guessing RiffRaff since you also have their boots, then you do not need plenum inserts. The inserts are only because the stocks ones are made of flimsy metal that cannot hold up to the clamping pressure. Aftermarket ones should stand up to as much clamping force as required.
2000 F-250 4x4 SuperCab Short Bed 7.3 w/ 280,xxx mi - 4" Pro Comp - Redhead - 37x12.50x17 BFG A/T KO - 3.73 Gears - CTS2 - Hydra - FFD 238cc/80%
KC38r 366 - Adrenaline - Irate Fuel System w/ Sump - 4"Exhaust - K&N CAI w/ S&B Filter - FFD Bellowed Up Pipes - AIH Plug - RiffRaff Plenums & Boot Kit
mcnance865 is offline
post #8 of 14 (permalink) Old 02-26-2018, 01:15 AM Thread Starter
levi7.3rig's Avatar
Ok, yes theyíre the riffraff ones. Thanks! What brand of pedestal delete should I go with?
post #9 of 14 (permalink) Old 02-26-2018, 04:23 AM
2000f250's Avatar
I run this on my 7.3 http://www.riffraffdiesel.com/garret...estal-99-5-03/ my only recommendation is hutch harpoon mod in fuel tank and fuel pressure gauge. Also replace all fuel sleeves on hard fuel lines and fuel bowl.
2000f250 is offline
post #10 of 14 (permalink) Old 02-26-2018, 08:29 AM
​ DieselDC's Avatar
#1, 3, 4, 5, 6, 7 etc. some links Iíve saved below for reference and an idea of what Iíve stated above.
óóóóóó-
I highly recommend these as a MUST from a reliability standpoint. Items Iíve purchased.(Updated 2/19/18)
1. Pedestal delete, and Garrett hotside http://alturl.com/x4ihd $250. Garett hotside fits cleanly vs generics
2. KBDP bellowed up pipes http://alturl.com/9qpeh $200.
3. Plenum inserts http://alturl.com/eppso $51 shipped
4. Fuel bowl reseal Ebay user: racecolo best instructions ever! Dummy proof trust me! https://tinyurl.com/ydxtyro9 $20 shipped
5. Fuel lines https://tinyurl.com/y8n4wnhs.us $280 shipped
6. HPOP reseal Ebay user: racecolo https://tinyurl.com/ycrzvjee $29 shipped
7. HPOP lines Ebayer: crudediesel heís local to me https://tinyurl.com/ycmlqfsb $155 shipped
8. Turbo rebuild: Ebay http://alturl.com/xrxtg $65 shipped. Has 360deg thrust bearing
9. Turbo outlet o-ring: Ebay F81Z-9E436-AA o-ring $8shipped
10. Upper radiator hose amazon #62491 $17 shipped. Route behind serpentine belt
11. Derale 14208 4r100 pan (adds 7qts extra) $130 http://alturl.com/kxbdt
12. Total: $1206
