DIY turbomaster - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 4 (permalink) Old 02-25-2018, 11:24 AM Thread Starter
DIY turbomaster
So yesterday I figured out that the wastegate went bad, cant have one delivered today and town & country ford wants 665.00 (yes just for the actuator). So out of necessity I built my own version of a turbo master, I used some allthread some various hardware and the guts of the old actuator! Gonna give it a try later after I find that damn e clip lol..... here are some pics if this helps anybody.
blueovalmaniac is offline
post #2 of 4 (permalink) Old 07-19-2018, 03:32 PM
Re: DIY turbomaster
How did this work out for you?
I think I have a similar issue, my wastegate actuator spring is not as strong as it needs to be after 20 years and many many heat cycles and allowing a little bit of a bypass under load. I was thinking of using a wire or something to hold the wastegate closed and not allow it to open at all to prove my thought...
01 F350 CCLB SRW
tubular031 is offline
post #3 of 4 (permalink) Old 07-19-2018, 10:24 PM
Re: DIY turbomaster
Many, many people wire the wastegate actuator shut. I have no experience with it, but I have seen it in many threads. Do searches about "tightening wastegate" and also if you read about the "red line mod", you will probably also see talk about using a wire to hold it shut.
2000 F-250 4x4 SuperCab Short Bed 7.3 w/ 280,xxx mi - 4" Pro Comp - Redhead - 37x12.50x17 BFG A/T KO - 3.73 Gears - CTS2 - Hydra - FFD 238cc/80%
KC38r 366 - Adrenaline - Irate Fuel System w/ Sump - 4"Exhaust - K&N CAI w/ S&B Filter - FFD Bellowed Up Pipes - AIH Plug - RiffRaff Plenums & Boot Kit
mcnance865 is offline
post #4 of 4 (permalink) Old 07-20-2018, 02:03 PM
Re: DIY turbomaster
oh yes I have had the red line attached to an IC clamp since 2007 when I got the truck. My thought is the spring in the WG controller is getting soft and not holding the WG closed like it should/use to. I have seen people wire it shut and that is what I am going to do to test my theory. I have just never seen anyone make their own adjustable controller. Thats the interesting part of this thread. I had thought about getting the kit from dieselsite but almost $200 seems a bit steep.
01 F350 CCLB SRW
