2001 f250 7.3 - PowerStrokeNation : Ford Powerstroke Diesel Forum
 1Likes
  • 1 Post By ​ DieselDC
post #1 of 9 (permalink) Old 01-23-2018, 04:49 AM Thread Starter
2001 f250 7.3
Hi guys. I bought a 2001 f250 7.3 a few months ago. It runs and drives alright. So far, Iím not thrilled with its performance. Everything in it is stock. Would adding a tuner help remedy this? I know a lot of people add intakes and exhausts too, but what exactly will that do for me and is it necessary? Iím hoping I can go with just the tunes. Also, I plan to start towing with this sometime (as soon as I work up the funds for a dump trailer). Are there any other mods that are essential to towing on these 7.3s? The dump trailer is pretty heavy... around 12k.
kcurbanloggers is offline
post #2 of 9 (permalink) Old 01-23-2018, 05:16 AM
​ DieselDC's Avatar
Re: 2001 f250 7.3
Well you should do some research -ó
I know a lot of people add I takes and exhausts too, but what exactly will that do for me
You need all of it.
Some ideas to get you started - and do some research on each. Based on what you want to do.....
Intake
Exhaust
Chip with a 45hp tune is all you need to tow heavy
Upgraded transmission cooler.
Thatís all you will need.
óóóóóóóó
above is for a healthy engine, injectors, turbo and Transmission etc. if itís all aging, youíre looking at throwing some money at it real quick. Will probably cost you a few grand in parts + your labor. If you need a transmission add another 3-5k. If you canít do it yourself, add in another 3-5k labor.
See where Iím leading you? Itís an aging truck and takes some serious $$$. If youíre gonna do it, do it right and you wonít worry for another 5-8yrs unless you get addicted to speed and go fast parts.
​ DieselDC is offline
post #3 of 9 (permalink) Old 01-23-2018, 10:44 AM
levi7.3rig's Avatar
2001 f250 7.3
The reason you need all of these upgrades is so you can keep egts and trans temps down. These numbers can skyrocket in a matter of seconds if something isnít right, or if youíre pushing the truck to hard, especially if youíre going to be towing. By the way, donít think gauges have been mentioned yet. Go with autometer or isspro for analog, nothing cheap like glowshift (glowshift can be inaccurate). Or if you want a digital monitor that has gauges for literally everything go with a cts monitor.
levi7.3rig is offline
post #4 of 9 (permalink) Old 01-23-2018, 12:54 PM Thread Starter
Re: 2001 f250 7.3
You need all of it.
Intake
Exhaust
óóóóóóóó
The truck only has 160k on the clock, and the tranny seems to be perfectly healthy. So adding the intake exhaust and tuner should save the tranny from overworking and self destructing?
post #5 of 9 (permalink) Old 01-23-2018, 01:15 PM
Moderator
Sbluke55's Avatar
Re: 2001 f250 7.3
The cooling for the trans is lacking in the 7.3. To save the trans, you need a 6.0 trans core.
As for a tuner do the hydra or dp tuner f6v2
01 f-250, Standard
Sbluke55 is offline
post #6 of 9 (permalink) Old 01-23-2018, 02:14 PM
2000f250's Avatar
2001 f250 7.3
I would do a 6.0 trans cooler 4 inc exhaust. 6637 intake and hydra or dp tuner and gauges trans temp egtís gauge. This is the setup I have but mine is built more with bigger turbo injectors and built tranny it is a beast but simple up grades will wake it right up. With out breaking the bank.
2000f250 is offline
post #7 of 9 (permalink) Old 01-23-2018, 02:43 PM
alleged moderator
tjctransport's Avatar
Re: 2001 f250 7.3
as said above, a 4 inch exhaust, 6637 intake, DP F6 or hydra with 40 or 60 HP economy tune, and a pyrometer to monitor exhaust temps will wake your 7.3 up nicely. th larger 6.0 trans cooler is nice, but not an absolute must have.
my 02 still runs the stock cooler and no problems at 195,000 miles, but i also do a complete trans fluid and filter change every 30,000 miles too.
tom
tjctransport is offline
post #8 of 9 (permalink) Old 01-23-2018, 03:03 PM
​ DieselDC's Avatar
Re: 2001 f250 7.3
Only the cooler will help prevent over heating of the transmission. Let me come up with a list for you.
post #9 of 9 (permalink) Old 01-23-2018, 03:32 PM
​ DieselDC's Avatar
Re: 2001 f250 7.3
As stated, do some research and let us know what you think or are confused about.
basic towing package (well not really basic)
1. Tuner - go with hydra http://alturl.com/37njc (cncfab is a sponsor here and heís tops in my book). I have this.
2. Intake - go with afe http://alturl.com/uh3a5. I have a K&N
3. Exhaust - 4Ē ss http://alturl.com/m9e7r
4. Transmission cooler - trucool - I have this and I think itís the best deal and better than any cooler you will find. http://alturl.com/i8ipw
5. Gauges for egt, transmission, boost. I would go with glowshift. http://alturl.com/mo7bc I have cheaper ones dating back to 2002 and it works fine. Look at #6
6. My next upgrade is the 3in1 http://alturl.com/aixfg
Note. The only gauge I look at is the EGT. Ever since I upgraded to the trucool - never have I once looked at my transmission. *** itís that good ***
I have included links all from one source: Ebay. You can shop where ever you want. Some places I shop at that I think are tops
Riffraff, cncfab, dieselsite. I like the convenience of Ebay b/c itís free shipping the majority of the time. If I need little items, then I go straight to Clay at Riffraff- that guy will help even if you donít buy his chit. The $15 shipping sucks though.
kcurbanloggers likes this.
