clutch upgrade - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 3 (permalink) Old 01-07-2018, 12:43 AM Thread Starter
Rookie diesel tech
evans735's Avatar
Send a message via AIM to evans735
clutch upgrade
so now that im done with school and officially full time i got some funds coming in and can finally do some upgrades to the truck. i already have the exhaust i want picked out. This is my first standard truck i dd. So for a clutch upgrade i want something that will be able to handle around 350-400 hp and thats good for towing all sorts of weight combinations.
2000 F350 7.3L ext. cab, long bed dually, ZF6, 340,xxx miles
6637 mod/ egt and boost gauges/ PHP hydra
evans735 is offline
post #2 of 3 (permalink) Old 01-07-2018, 01:03 AM
​ DieselDC's Avatar
Re: clutch upgrade
I donít know too much about the standards but I know where you can get one: cncfab.us Corey will take care of you.
https://www.cncfab.us/shop/south-ben...-03-fddc36006/
Another place I shop at is swamps
https://swampsdiesel.com/shop/produc...999-03-clutch/
Canít go wrong with Corey or Jonathan!
​ DieselDC is offline
post #3 of 3 (permalink) Old 01-14-2018, 12:29 PM
Re: clutch upgrade
For many years, I've towed a loaded 4-horse trailer with living quarters all over the Western US. In your stated HP range, I've had excellent results with the South Bend 1944-6OFEK.
If you intend at some point to increase your HP range, then you'd probably be wise to select one of South Bend's dual disk clutches.
1OldMan is offline
