turbo rebuild or KC38r? - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 4 (permalink) Old 01-02-2018, 11:16 PM Thread Starter
I know the KC would be the better overall set up, but at more than 1000 more, it hurts my budget AND its a few weeks out at best (ive already been told 2 weeks like 4 weeks ago).
Need to do up pipes, and rebuild my badly leaking fuel bowl ASAP. Figured while I was in there to do boots, glow plugs, gaskets, etc. Im at 185K on the odo. I mostly daily drive on the freeway, and tow 10K fairly often.
Was looking at either going to the KC38r turbo OR rebuilding mine with a riffraff wheel, EBV delete pedestal, high flow outlet and 360 bearing kit and a turbo master wastgate. This will be about 1K less than a new turbo.
I dont need to be the fastest out there, but would like to lower my EGT's while towing, and having more power for climbing the sierras would be nice. Would I be happy with the rebuild or do I really need to just pony up for charlies turbo?
stock injectors and hpop, 4" exhaust and DP tuner.
02 crew cab 4x4
61 scout 80 rock crawler
plug ugly is offline
post #2 of 4 (permalink) Old 01-02-2018, 11:27 PM
​ DieselDC's Avatar
Rebuild it. Youíll be fine. BTW I have the Kc38r stg2. Itís a kick ass turbo but it will also kick your bank account as youíve mentioned.
WW2 from diesel site is what I would use. Even their turbo is tops - everything they sell it tops. They too are local to me.
Here are some upgrades and links and or contacts
I highly recommend these as a MUST from a reliability standpoint.
1. Bellowed up pipes https://tinyurl.com/y9pps8nh
2. Pedestal delete https://tinyurl.com/y785a64v
3. Fuel bowl reseal Ebay user: racecolo best instructions ever! Dummy proof trust me! https://tinyurl.com/ydxtyro9
4. Fuel lines https://tinyurl.com/y8n4wnhs cncfab.us
5. HPOP reseal Ebay user: racecolo
6. HPOP lines Ebayer: logsdonindustries heís local to me https://tinyurl.com/ycmlqfsb
​ DieselDC is offline
post #3 of 4 (permalink) Old 01-03-2018, 01:29 AM Thread Starter
Re: turbo rebuild or KC38r?
how big of a difference did you notice between the two turbos?
02 crew cab 4x4
post #4 of 4 (permalink) Old 01-03-2018, 01:46 PM
Moderator
Sbluke55's Avatar
I would get all your orings from dieselorings.com
For the up pipes use Amazon and they are under $100.
Use ford uvch and glow plugs. Skip the waste gate actuator. Was of money. Then just get a billet wheel and a 360* thrust washer rebuild kit.
01 f-250, Standard
Sbluke55 is offline
