plastic clip on clutch rod - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 5 (permalink) Old 12-22-2017, 11:05 PM Thread Starter
Rookie diesel tech
evans735's Avatar
Send a message via AIM to evans735
so my plastic clip that attaches to the clutch pedal keeps popping off. i have zip ties keeping it on right now for it pops off. im curious if there is a easy fix to this at all?
2000 F350 7.3L ext. cab, long bed dually, ZF6, 340,xxx miles
6637 mod/ egt and boost gauges/ PHP hydra
evans735 is offline
post #2 of 5 (permalink) Old 12-22-2017, 11:06 PM
79jasper's Avatar
Re: plastic clip on clutch rod
Heim joint mod.
79jasper is offline
post #3 of 5 (permalink) Old 12-22-2017, 11:06 PM
​ DieselDC's Avatar
I donít have a manual but an auto. You have a pic? Could probably come up with a more permanent solution.
​ DieselDC is offline
post #4 of 5 (permalink) Old 12-23-2017, 02:17 AM
2000f250's Avatar
Hi Evans735 this link might help you I hope. https://youtu.be/6C75oQNNows
2000f250 is offline
post #5 of 5 (permalink) Old 12-24-2017, 09:18 PM Thread Starter
Rookie diesel tech
evans735's Avatar
i think im either going to do the hem joint kit or just for now cut the tabs off and leave the rod circle and slip it on and use a trailer clip pin with a washer to keep it on. thanks for the advice guys!!
evans735 is offline
