New injectors - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 9 (permalink) Old 12-19-2017, 01:07 PM Thread Starter
Horny toad's Avatar
New injectors
Looking at getting new higher performance injectors the truck is running stock injectors what brand and size would you guys recommend the truck has a ts6 chip
Horny toad is offline
post #2 of 9 (permalink) Old 12-19-2017, 01:25 PM
​ DieselDC's Avatar
Re: New injectors
160/30. I got PIS injectors. They are good injectors and they are under new management. Had an interaction with them that I wasnít too pleased just recently so that puts a mark on them so now I wonít recommend them but their injectors are solid thus far. Only time will tell.
Rose wood, full force diesel, swamps. Canít go wrong with either.
​ DieselDC is offline
post #3 of 9 (permalink) Old 12-19-2017, 01:59 PM Thread Starter
Horny toad's Avatar
You think the 160 /30 from either of the manufacturers?
post #4 of 9 (permalink) Old 12-19-2017, 03:50 PM
'Cody''s Avatar
Re: New injectors
What's your plans with the truck. How big you willing to go? How much power you want? You planning to do hpop, fuel system, turbo, or tranny work?
I have 160/30s and love them. You pretty much need to copy my sig to get the most out of them. If your not willing to go that far then I would recommend 160/0 or baby swamps.
Old Blue, 97' F350, CCLB, 7.3, Auto
Air: SD IC, 3" Plenums
Fuel: E- Fuel, 160/30 Injectors
Turbo: Irate T4, S366
Oil: T500, Melling LPOP
PCM: TW TS, IDM Mod
'Cody' is offline
post #5 of 9 (permalink) Old 12-26-2017, 09:20 PM
Re: New injectors
160/80s; NOT NOT NOT 160/30s. Easy to tune and shorter PW (advantageous).
Ask ACTUAL tuners what THEY think.
97 F350 XL std cab, zf5, srw (converted), 4wd, 3.55s, stock wheels/tires & rebuilt 9.19
2 Donaldsons, 3" dp, ACs, T500, HV LPOP, Hydra w/PHP, DIY 60 gl tank w/6 gl sump, eFuel/Cat filters, Aeromotive RR, Auber instruments, 140v IDM, KC 300X 63/70/84, boost fooler, RiffRaff bellowed up pipes, 6.0 IC, 3" plenums w/RiffRaff inserts & SB 425HD
MeTo is offline
post #6 of 9 (permalink) Old 12-26-2017, 11:24 PM
'Cody''s Avatar
Re: New injectors
Many tuners recommend a smaller nozzle. 160s can easily empty fast enough through a 30% nozzle. You also get better atomization out of a smaller nozzle. The only time a larger nozzle is better is at a high rpm.
I do agree you should ask your tuner what they recommend.
PCM: TW TS, IDM Mod
'Cody' is offline
post #7 of 9 (permalink) Old 12-26-2017, 11:41 PM
Rookie diesel tech
evans735's Avatar
Send a message via AIM to evans735
Re: New injectors
the 160/30's are great for improved towing and mpg performance. as stated above the better the fuel atomizes the better it will be burned off and used which therefore is turned into better mpg and hp gain. but like it was stated as who ever you are going to have retune your ts chip ( it will have to be retuned with upgraded injectors) what they recommend with their tunes.
2000 F350 7.3L ext. cab, long bed dually, ZF6, 340,xxx miles
6637 mod/ egt and boost gauges/ PHP hydra
evans735 is offline
post #8 of 9 (permalink) Old 12-26-2017, 11:47 PM
'Cody''s Avatar
Re: New injectors
I know its kinda uncool to link to other sites but alot of great info on this subject can be found in this thread. If you delete this link I totally understand.
Detuning large injector nozzles - How to pick injector size for upgrades! - PowerStrokeArmy
PCM: TW TS, IDM Mod
'Cody' is offline
post #9 of 9 (permalink) Old 12-27-2017, 01:17 AM
​ DieselDC's Avatar
Re: New injectors
200/30 will empty completely up to 3700rpm. You donít want to exceed 3400 anyways.
