7.3 alternators - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 20 (permalink) Old 12-05-2017, 12:05 AM Thread Starter
7.3 alternators
Noticed that a 94-97 has the alt and ac opposite of the setup on a 99-03. Could you take a bracket from a 94-97 and bolt it on a 99-03? Like say if I wanted to put two alternators on my 01 by pulling off the ac bracket and bolting on an alt bracket from a 94-97?
Momentum wins over traction every time.
Mwsfarms is offline
post #2 of 20 (permalink) Old 12-05-2017, 04:11 AM
Project Shamu
Lt.Dan's Avatar
Re: 7.3 alternators
It sounds plausible. I've never seen it done, but i know the blocks are the same 94-03, so the bracket should bolt up just the same. Belt length I could see being a little difficult getting down. And obviously wiring the 2nd alternator.
1996 Cali F350 CCFB, 7.3 PSD, 2wd SAS, w/ 378,000 miles.
New Motor at 352,000, DieselSite Legendary Trans at 356,000 and many more
1983 F150 SCSB Flareside, 302 w/ AOD Trans
2002 F450 SCFB, 7.3 PSD 2wd w/ 144,000 miles
SOLD
Lt.Dan is offline
post #3 of 20 (permalink) Old 12-05-2017, 10:35 AM
alleged moderator
tjctransport's Avatar
Re: 7.3 alternators
the second alternator on the dual alternator truck is under, not on top. so i don;t think it would work.
tom
tjctransport is offline
post #4 of 20 (permalink) Old 12-05-2017, 11:45 AM
Moderator
Sbluke55's Avatar
Re: 7.3 alternators
Why do you want two alts
01 f-250, Standard
Sbluke55 is offline
post #5 of 20 (permalink) Old 12-05-2017, 12:19 PM Thread Starter
I have dual alts on my chevy 350. It used to be the work truck so I had one alt that ran the truck and another alt devoted to a separate battery. I set it up that way so I could run an inverter, lights, etc without affecting the trucks original system. I plan to do this with my 7.3 now
Mwsfarms is offline
post #6 of 20 (permalink) Old 12-05-2017, 12:22 PM Thread Starter
Wiring wonít be bad at all. I wonít mess with the system now. This alt will have a separate battery to charge and wonít be wired to the rest of the electrical system of the truck
Mwsfarms is offline
post #7 of 20 (permalink) Old 12-05-2017, 01:09 PM
Moderator
Sbluke55's Avatar
Re: 7.3 alternators
The alts on the obs are a one wire alt. So like you said. Wiring is easy. The superduty bracket also houses the power steering pump. On the obs, doesnít that bracket house the vacuum pump? It might be easier to make a mount to adapt the alt to the a/c bracket.
01 f-250, Standard
Sbluke55 is offline
post #8 of 20 (permalink) Old 12-05-2017, 01:21 PM
Master BS'er
jamiesaun's Avatar
Re: 7.3 alternators
I worked on a c4500 Duramax a couple weeks ago that had two alternators and 2 ac compressors. It was a big ass charter bus type thing, anyway, it had custom brackets and obviously a custom order belt too.
Maybe look at some pictures of buses or something with 7.3 in it and see how they did it.
Brother James
Ps...Im pretty frickin awesome!
jamiesaun is offline
post #9 of 20 (permalink) Old 12-06-2017, 01:44 AM Thread Starter
Would the pumps absence matter? I thought about doing the add on alt with the bracket from ford and still havenít ruled that out. I just figured I could get an alt bracket for less at a upull vs the auxiliary bracket from ford. I didnít think finding a belt would be terribly hard but I may be wrong
Mwsfarms is offline
post #10 of 20 (permalink) Old 12-06-2017, 01:50 AM Thread Starter
The buses have the alt on the correct side but the bracket looks like the alt will stick out to far. I thought about making a bracket the worst part will be insuring the belt runs straight. Thatís where I figured the 94-97 bracket would be worth it IF it bolted on in place
Mwsfarms is offline
