Whicked Wheel Installed - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 19 (permalink) Old 02-28-2010, 01:04 PM Thread Starter
Powerstroke Addict
Nally7.3Powerstroke's Avatar
A few months back I put one of XDP's X-Wheels on my truck and it helped out bigtime with the surging and it sounds great too. I finally got around to uploading a few pics so here they are.
http://i278.photobucket.com/albums/k...k/IMG_0702.jpg
http://i278.photobucket.com/albums/k...k/IMG_0701.jpg
http://i278.photobucket.com/albums/k...k/IMG_0704.jpg
Nally7.3Powerstroke is offline
post #2 of 19 (permalink) Old 02-28-2010, 01:17 PM
Banned
Re: Whicked Wheel Installed
Nally on a 1-10 scale how difficult is the install? Really been thinking about one of these.
Thanks
Enoch is offline
post #3 of 19 (permalink) Old 02-28-2010, 01:34 PM Thread Starter
Powerstroke Addict
I would say its around a 4 maybe, I dont think it was that bad at all. Alot of people recommend taking the turbo completely off the truck to install it but its completely unnecesary. Just pull the intake tube off, and I believe the bolts holding the compressor housing on are 12 point 10mm, so if you have an air ratchet use that to remove them. Then once your housing is removed you can use an impact gun to torque the old wheel off.. and then spin the new wheel on. Its really not hard at all and takes maybe 2 hours to do. The only difficulty was getting to the rear and bottom bolts on the housing, i needed a swivel socket for that and it was hard to line up sometimes.
post #4 of 19 (permalink) Old 02-28-2010, 01:39 PM
mnstroker's Avatar
I took my turbo off, but I had leaky orings to replace too.
Back to stock for now.
Originally Posted by 1800joedaddy View Post
It's one thing to get cornholed... its another to pay for the cornholing!
mnstroker is offline
post #5 of 19 (permalink) Old 02-28-2010, 06:06 PM
Banned
Thanks, I'll have to look into getting one and make a day of it and do the foil delete and polish the tubes while I'm at it.
Enoch is offline
post #6 of 19 (permalink) Old 02-28-2010, 06:16 PM
HHAUL'N STROKER
SMOK'N BLUE STROKER's Avatar
Impact gun to remove old wheel = way bad idea!!!!
SMOK'N BLUE STROKER is offline
post #7 of 19 (permalink) Old 02-28-2010, 11:30 PM
Custom Trailer Sales
TrailerHauler's Avatar
Nally's pretty close to spot on with the install. Don't bother pullng out the turbo to do it, I had it in and done in maybe under an hour. The only thing not mentioned was the waste gate. Removal's self explanatory, I just unbolted it from the compressor housing and pulled it out and off to the side.
Why's that? I did it and my turbos fine, I don't see how else you could do it anyway.
I just put a WW in my truck about a month ago, and I have to say it makes a world of difference! It's well worth its weight if your truck has ever surged!! I recently pulled one of my heaviest loads yet after putting this wheel in and couldn't get it to surge even when I tried to. Sure does sing louder to!
1999.5 F350 PSD CC Dually 05' Conversion
Stage I's - Gearhead Tuning - BTS - PCS
F550 rear suspension
1999.5 F350 PSD S/C 6spd Dually
R.I.P. Will Iott - "This ain't no practice run"
TrailerHauler is offline
post #8 of 19 (permalink) Old 02-28-2010, 11:34 PM
just a welding fool.
Hawker's Avatar
i did mine with an impact too, no problems. After Swamps 175/146 sticks, I have noticed some surge around 15-20 psi goin up a hill, really into it. guess i'm just gonna have to go to a 38r now...
Swamps
Gearhead Tuning
Diesel Innovations
Hawker is offline
post #9 of 19 (permalink) Old 02-28-2010, 11:39 PM
HHAUL'N STROKER
Um pull turbo off. Hold exhaust side while taking off compressor wheel. I for one wouldnt spin my turbo without oil in it. But hey to each ther own. I just like doing things the right way not being lazy and half assn it.
post #10 of 19 (permalink) Old 03-01-2010, 12:21 AM
PSN Pretender
907DAVE's Avatar
How are you holding "the exhaust side"?
907DAVE is offline
