AFE stage 2 dry filter - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 7 (permalink) Old 02-27-2010, 11:49 PM Thread Starter
porkchop's Avatar
Got a quick question for the guys running AFE's dry filter. What do you do to clean it?? my buddy has one on his 7.3 and doesnt know what to use since its a dry filter and not oiled..?
porkchop is offline
post #2 of 7 (permalink) Old 02-27-2010, 11:55 PM
We put the FU! in FUN
F250Hoss's Avatar
Re: AFE stage 2 dry filter
i thought u just washed it like normal and then let it dry and then re install
Bored .030 HHT Waste gate,Wicked Wheel, K&N intake, 4" Turbo back, HPX Line , 6.0 Tranny Cooler, IDM MOD,3 Gauge Pillar W/ Auto meter Ultra Lites with LED's, LED Interior lights,
Bestop Soft Top,35W HID's 6K,Pioneer AVHP4200DVD 7",Rockford P2 10" ,Phoniex Gold Door Speakers,JL Amp
F250Hoss is offline
post #3 of 7 (permalink) Old 02-27-2010, 11:56 PM
treyloco's Avatar
dishwashing liquid and warm water. Mix in a bucket and drop the filter in and let it sit for a while then rinse it off with water from the inside out.
'03 7.3 lariat crew cab dually FX4
AFE Stage 2
DI 6 position
warn premium hub locks
4" mbrp straight piped exhaust
custom built trans w/ triple disc converter
'07 Front End w/ 6000k HID
AIH delete & CCV Mod
Just over 100k miles
"Powerstroke Performance Headquarters!"
treyloco is offline
post #4 of 7 (permalink) Old 02-28-2010, 12:15 AM
TARM's Avatar
I have used Simple green with very good results. I had a deal that mine came with the kit. Simple Green IMO works better and you can get it at just about anywhere. I have not noticed any issues with the filter media. I mix it with water in a pail and let it soak for a while then rinse well. Let dry.
TARM is offline
post #5 of 7 (permalink) Old 02-28-2010, 12:32 AM
Edward Scissorhand WanaB
Bushwakd's Avatar
Clean just like the others have described and be careful not to disturb the filter media. No heavy force of water and do not use an air hose to dry it. It will separate the filter media fibers and reduce the effectiveness of filtering.
A filter sock which is a thin material that covers the filter helps to keep the heavy debris out of the filter pleats.
This is only an example of the pre-filter sock. There are several color options and logos on the internet.
http://www.dp-tuner.com/index.php?p=...=131&parent=15
"Real Trucks Don't Have Sparkplugs"
2000 F-250 Lariat, CC, 4x4, LWB,
A few mods to make it better than stock.
250cc hybrids, Stealth stage II HPOP, H-11 Headstuds, Strickly Diesel Reg. Return Fuel, Spearco 6.0 IC, Garrett 38r 1.15 hsg, BTS transmission, Gearhead Tuning
"The Smoke Don't Mean Its Broke"
Bushwakd is offline
post #6 of 7 (permalink) Old 02-28-2010, 01:58 AM
TARM's Avatar
Sorry I forgot to add that was a oiled washable filter not a dry washable one. I think they actually can use the same cleaning chemicals but have not had to personally. On wash what I actually do is let it soak over night or a few hours. Then I let the water run over the out side and then allow the water to run inside and push everything outward so am debris is pushed out the direction it came in ( to the outside. Then I give it a few dunks and swirls in a clean bucket of water only.
TARM is offline
post #7 of 7 (permalink) Old 03-02-2010, 03:05 PM
DSTRBD's Avatar
Knock all the big crap off and spray it out with water. Let the filter dry, then re-install.
DSTRBD is offline
