Replaced Turbo, HELP!!! - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 3 (permalink) Old 02-27-2010, 03:09 PM Thread Starter
ZF6 swap, COMPLETE!!
blitzkreig27's Avatar
Send a message via AIM to blitzkreig27
Exclamation Replaced Turbo, HELP!!!
I just bought the D66 turbo from bean and replaced it. The turbo is great, my mechanical skills, not so much. I installed it using the directions bean gave me and made sure everything was back in place. After I let it idle for about 4 mins at 1000rpm, I put my stock tune on. White smoke from under the hood and exhaust. The 140+ tune gave me white from the hood and blue from the exhaust. I checked for leaks and all the tubes for oil but I'm stuck. Stock builds up slower than normal and 140+ is better but of course with blue smoke. Thanks in advance for any help!
Early 1999 F-250 SD 7.3L 4X4 Long bed, Superchips Programmer, Beans custom 6-Position tunes, S&B Filters Intake, Dominator 66 turbo from Bean, 5" Turbo Back w/ 2 7"/36" angle cut, South Bend 450hp clutch kit, ZF6 swap, *210000* miles
blitzkreig27 is offline
post #2 of 3 (permalink) Old 02-27-2010, 04:09 PM
Re: Replaced Turbo, HELP!!!
jk... white smoke from under the hood? Sounds like something is burning off the exhaust (oil?)... prob not an issue assuming some dripped onto it during the install... see if it continues
02 F250 PSD 7.3L
Tymer,Irate T4 mount with S366 Turbo, 5in SP,triple gauge pod w\ Di-Pricol Optix (EGT,Boost,tranny temp)
CCV Mod, In-tank mod, Harpoon mod, Airdog, ITP regulated Return (8LL replaced with AD)
Oilguard Bypass Oil System
Dieselsite Coolant Filter, Fluidampr
ITP boost Annihilator, BTS Trans and T.C.
DP tuner 6 position
02powerstroke is offline
post #3 of 3 (permalink) Old 02-27-2010, 09:56 PM Thread Starter
Thx ill see if anything is loose.
