T&S chip stopped working - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 3 (permalink) Old 11-09-2017, 09:59 PM Thread Starter
My chip just randomly stopped working.
The truck runs fine but it's stuck in stock mode. No matter which position I turn the chip to, nothing changes.
Truck ran okay with it before, lots of smoke (which I'm pretty sure means it was a ####ty tune) but it was very noticeable none-the-less.
Is this an easy fix or should I ditch this thing for a better tuner?
beef tits is offline
post #2 of 3 (permalink) Old 11-09-2017, 10:26 PM
79jasper's Avatar
Re: T&S chip stopped working
I would check to see if it came unplugged.
79jasper is online now
post #3 of 3 (permalink) Old 11-09-2017, 10:33 PM
​ DieselDC's Avatar
Send it it to get tested but again ainít worth it for the test fee b/c It would be 1/3 of a new one if it was found to be bad (which I think it may be bad) if all is well with the pcm. I have the hydra and will also have my pcm flashed later for the 120 tune (which Iím on all the time). If hydra quits working - pcm will still work. I donít even have the lcd selector hooked up - just the tuner installed in the pcm.
​ DieselDC is offline
