manual hub fitment - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 3 (permalink) Old 11-09-2017, 05:39 PM Thread Starter
cpdad93's Avatar
manual hub fitment
My 97 TTB is in the junk pile and my 02 superduty axle is ready to be finished. The Mile marker site has the same hub fitting both axles. Does this mean the TTB hubs will fit on the superduty? If not is around $150 plus the conversion kit a good price for the milemarker? Thanks, Don
cpdad93 is offline
post #2 of 3 (permalink) Old 11-11-2017, 01:09 PM
410customs's Avatar
Re: manual hub fitment
Pretty sure its the same hub, try it and see!
FYI your TTB was a dana 50 your new SD axle is a dana 50 also
Milemarker 449SS kit runs about $150 new comes with everything you need to install
You do not need the conversion kit unless you are switching from auto to manual hubs, the conversion kit is simply inner and outer spindle nuts and the lock ring washer...most auto parts places carry these also
2001 Excursion 7.3, auto, 4x4, 3.73, collecting parts for suspension lift
2000 E350 7.3, auto 2wd, 3.73, toy hauler camper conversion...researching 4x conversion
21.9 liter family
410customs is offline
post #3 of 3 (permalink) Old 11-21-2017, 01:57 AM
Garage
Check out the superwinch manual hubs. 100% no questions warranty. And my friend used the same model lockouts on his 97 that i used on my 99
1999 F350 Ext cab LB UFiberglass utility body SRW 4x4 auto
Magnaflow 4" turbo back
PHP Hydra with swamps tunes
08 style tow mirrors
jesse24spd is offline
