Onboard battery maintainer - PowerStrokeNation : Ford Powerstroke Diesel Forum
 2Likes
  • 1 Post By ​ DieselDC
post #1 of 7 (permalink) Old 10-31-2017, 08:55 PM Thread Starter
What does everyone recommend for a AGM battery maintainer? Wanting something I could wire up to the block heater with a switch to the heater.
loganhorse is offline
post #2 of 7 (permalink) Old 10-31-2017, 09:16 PM
​ DieselDC's Avatar
Re: Onboard battery maintainer
Battery maintainers worth a dang are the ones called Noco genius. I have the 15amp charger and boy let me tell you!!! Saved quite a few batteries deemed bad by autozone and etc. recently saved a battery from a mazarati (sp?) that was on its third battery!
loganhorse likes this.
​ DieselDC is offline
post #3 of 7 (permalink) Old 10-31-2017, 09:16 PM Thread Starter
Ill check into them.
post #4 of 7 (permalink) Old 11-01-2017, 01:48 AM
PSN intsigator
heavydoc's Avatar
I've been thinking about doing that, just not sure what charger to use. I will look into those also.
Sent from my super samsung note 5
96 F350 rclb drw 2wd psd (built not bought)
01 Excursion Limited 4wd psd (the wifes ride)
02 F350 cclb drw 4wd psd (the land yacht)
heavydoc is offline
post #5 of 7 (permalink) Old 11-01-2017, 01:49 AM Thread Starter
Keep me updated what you use.
post #6 of 7 (permalink) Old 11-01-2017, 03:37 AM
Project Shamu
Lt.Dan's Avatar
I've had good results with a battery tender brand. I bought the one with 4 outputs, 4 amps each. Works great.
1996 Cali F350 CCFB, 7.3 PSD, 2wd SAS, w/ 378,000 miles.
New Motor at 352,000, DieselSite Legendary Trans at 356,000 and many more
1983 F150 SCSB Flareside, 302 w/ AOD Trans
2002 F450 SCFB, 7.3 PSD 2wd w/ 144,000 miles
SOLD
Lt.Dan is offline
post #7 of 7 (permalink) Old 11-01-2017, 03:50 AM
​ DieselDC's Avatar
Donít know how to quote both you guys but the brand I listed is the chit. No other battery charger/tender will revive a dead battery like the noco - itís expensive though so keep that in mind. I have 3-4 other chargers that I bought over the years and I just want to give them away b/c they are inferior. I bought a chitter yellow top on cl just to see if it will work. Well for $20 bucks, itís still in one of my cars 2yrs later lol. Cheers!
