whether to tap for EGT or pull off uptube and drill - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 13 (permalink) Old 02-25-2010, 01:34 PM Thread Starter
Got my EGT sensor yesterday and called my buddy who's a diesel mechanic to have him tap for it. He told me that he could do that, but with my truck being an 02 he said he'd really rather take off the uptube for the turbo and drill itn then seal it from both sides since my pipings not brand new and the threads my not take. He wants 100 plus 20 per broken bolt if they break. Should I just tell him to tap it or pay the extra money to do it his way. Any input or opinions would help
02 F250 7.3L PSD, 6sp manual, 4WD, SCT livewire, AFE custom WAI, single stack, no muf, 285 BFG AT
dpmoore1982 is offline
post #2 of 13 (permalink) Old 02-25-2010, 01:46 PM
All done now
Arisley's Avatar
Re: whether to tap for EGT or pull off uptube and drill
I would put the probe in the driver side exhaust manifold. It is cast iron. It is so easy, even a caveman coould do it.
Arisley is offline
post #3 of 13 (permalink) Old 02-25-2010, 01:58 PM
Lovin the Tuna
RedSmokey's Avatar
You dont need to pull anything off. Just like Arisley said, use the driver side exhaust manifold. Drill it, tap it, and screw in the probe. Its easy...
2001 F250
2000 F250
RedSmokey is offline
post #4 of 13 (permalink) Old 02-25-2010, 02:10 PM
white7.3's Avatar
Thats what i did... Pretty easy only took like 5 miutes to install the probe... Just do it yourself....
2001 F-250 4x4 ECSB
7.3 PSD DP Tuned
6.0 I/C Van Turbo & WW
6637 Intake 5" Exhaust
Custom RR Fuel System
05 Grille/08 Center Console
Raptor 372 w/ Toyo Open
Country AT2 35/12.50
white7.3 is offline
post #5 of 13 (permalink) Old 02-25-2010, 05:49 PM
What else?
smokyred's Avatar
Mine is in the manifold now, but when I had stock up-pipes I had it in the up-pipe. I just drilled the hole and welded in the bung that came with my gauge, and it worked pretty nicely. Easy drilling and good threads.
Dave
smokyred is offline
post #6 of 13 (permalink) Old 02-25-2010, 06:01 PM
HRT Performance
HotRodTractor's Avatar
Drill and tap from the bottom of the truck on the rear of the driver's side manifold. Don't worry about taking anything apart.
2006 Dmax MPI compounds
2015 VW Jetta TDI
2006 VW Jetta TDI
HotRodTractor is offline
post #7 of 13 (permalink) Old 02-25-2010, 09:18 PM
FORD..THE ROCK CRUSHER
Ron's power stroke's Avatar
i did just
Ron's power stroke is offline
post #8 of 13 (permalink) Old 02-26-2010, 01:17 AM Thread Starter
Thanks guys, tapped it today and skipped pulling anything off, Seems to work great, now to spend hours comparing my EGT temps to others on this site. Thanks guys, saved me some cash and stress.
post #9 of 13 (permalink) Old 02-26-2010, 02:11 AM
Well Hung Member
stroked's Avatar
try to limit it to 1250, 1300 degrees, for any extended periods
Donnie
2001- just the basics
2005 6.0 Studded, Deleted, 58v Swamps/PHP tuned Ficm, SOLD
99.5 hybrids, termy modded 17*, GT4294 TOTALED
stroked is offline
post #10 of 13 (permalink) Old 02-26-2010, 02:27 AM
tbolt's Avatar
Good job. It's really the easiest part of the install. Did you set the depth of the probe to center it in the manifold?
Glen
early99 f350 cc, lb, 2wd, drw, A pillar autometer guages, CTS monitor, AIS intake, 4" turbo back cat delete diamondeye exhaust, dptuner, pmt1, jw vb, Swamps ab inj, Adrenaline oil, Coolingmist, 180*T, Trucool cooler, spin on trans filter, Firestone air bags, 2" frt leveling kit, now chased by a 34' toyhauler
tbolt is offline
