DIY Intake question... - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 32 (permalink) Old 02-23-2010, 01:54 AM Thread Starter
Firefighter/EMT
NH OIL BURNER's Avatar
I put a 46637 filter in today and removed the airbox. I was wondering if leaving the air intake temp sensor unplugged will hurt anything...and i also have a custom made vacuum hose on my waste gate with a small hole in it for more boost (my friend hooked me up with it) i think it gives me maybe like 2 more lbs. I get a small turbo "blow off" sound when i shift and im wondering if that is boost going back through the filter???
02 F250 6 speed with 270k- SOLD
05 F350 auto with 94k, 4in MBRP with 6in tip, updated fuel pressure spring, and auto meter fuel press, boost, trans, and pyro guages, and tuning by vivian and PHP's FICM tuner currently running hercules! NO STUDS!
14.1 @ 95 is the best so far!
NH OIL BURNER is offline
post #2 of 32 (permalink) Old 02-23-2010, 02:00 AM
lincolnlocker's Avatar
Re: DIY Intake question...
aits is ok to stay unplugged just set it underneath the filter.. that sound would be the turbo surging...
00,f350 lariat,4x4,cc,drw,38r,bdp stage 2/170cc/100s,bdp live tunes,4''down 5''back,dieselsite adrenaline,diy RR w/walbro,bellowed uppies, BTS trans!
01, rclb, 4x4, zf6, caned ts tunes, xl work truck package, 4'' tbe
lincolnlocker is offline
post #3 of 32 (permalink) Old 02-23-2010, 02:01 AM
Just zip tie the sensor to the nearest bracket, it won't hurt a thing. Can't speak to your other question.
Early 99 F-250 XLT Extended Cab 4x2. XLE4 PCM, BTS Transmission, pre pump fuel filter,CCV Mod, DIY TYMAR, Coolant Filter, 48 Gal Transfer Flow Mid-Ship Fuel Tank
FleetMan is offline
post #4 of 32 (permalink) Old 02-23-2010, 02:03 AM
Thomas7.3psd's Avatar
the pachssssss sound is normal for the 6637. lol how ever you wanna spell it we all know the sound.
02 F250 cc sb Lariet 4x4.
BTS Transmission installed/tuned by TSD
Autometer Ultralite II Trans,Pyro,Boost.
MBRP 4'' Cool Duals turboback with 5'' tips.
DIY tractionbars with Procomp mounts.
6637/zoodad intake,Drilled/slotted Rotors.
Thomas7.3psd is offline
post #5 of 32 (permalink) Old 02-23-2010, 04:47 AM
Myles_S's Avatar
Psssshhhhh
99.5 F250, 4x4, Lariat, CC/SB, 4r100 Gauges, Intake, Exhaust, Lots of black/smoked parts
Originally Posted by Coltaine View Post
I ride solo, being able to converse with yourself is a skill that creeps up on you.
Black Ops 360
Gamertag; See Ya LATER 73
Myles_S is offline
post #6 of 32 (permalink) Old 02-23-2010, 07:49 AM
TARM's Avatar
From hard WOT at max boost and let off it sound like a fat ass fart.
TARM is offline
post #7 of 32 (permalink) Old 02-23-2010, 10:55 AM
All done now
Arisley's Avatar
No that sound on let off is not surge. Surge happens under load, surge is bad. That sound is normal. Actually I love that sound.
Arisley is offline
post #8 of 32 (permalink) Old 02-23-2010, 12:49 PM Thread Starter
Firefighter/EMT
I do too i jut never heard it come through the intake with the stock box in it. I have heard of people with turbo cars blowing their filters out that why i was asking! I am suprised how easy it was to make that intake...
post #9 of 32 (permalink) Old 02-23-2010, 07:16 PM
Myles_S's Avatar
better than spendin $280 on an S&B or somthin huh
Black Ops 360
Myles_S is offline
post #10 of 32 (permalink) Old 02-23-2010, 08:48 PM
TARM's Avatar
You do not hear much of anything on closed up stock or other sealed box. The way the filter is set in their it would be very hard for it to blow off not to mention with the amount of flow the pressure is likely quite low against it. Its only a stock turbo after all.
TARM is offline
