helping or hurting?? - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 10 (permalink) Old 02-20-2010, 09:41 PM Thread Starter
FORD..THE ROCK CRUSHER
Ron's power stroke's Avatar
help me out guy's..I really want swamps 238's but cant swing it this year.. I have the Adrenaline on order for my stage 2's in my sig..I also have ITP's bowl delete kit on order and getting rid of the DP and go with Bill..only cause he has done a lot of tuning with the Adrenaline and knows how they work..that should take care of the oil side..now I want to take care of the fuel side..id like to do a sump..not sure of the price or if I could swing that ether, if not.I'm thinking 5/8 pickup out to my 1212 Baldwin then into a Walbro fuel pump then into my Wix 2 micron spin on filter..from there 1/2" to the ITP bowl delete kit..then run my return back though the stock feed line..am over doing it?? or will I be hurting it??
thanks Guy's
Ron's power stroke is offline
post #2 of 10 (permalink) Old 02-20-2010, 09:43 PM
Myles_S's Avatar
Re: helping or hurting??
Sounds good to me
99.5 F250, 4x4, Lariat, CC/SB, 4r100 Gauges, Intake, Exhaust, Lots of black/smoked parts
Originally Posted by Coltaine View Post
I ride solo, being able to converse with yourself is a skill that creeps up on you.
Black Ops 360
Gamertag; See Ya LATER 73
Myles_S is offline
post #3 of 10 (permalink) Old 02-21-2010, 04:31 AM
<<< Power
chvyrkr81's Avatar
You might as well up the return to 3/8ths while you're at it.
That pump is gonna push alot of fuel.
06
02
97
74
chvyrkr81 is offline
post #4 of 10 (permalink) Old 02-21-2010, 07:37 AM Thread Starter
the stock feed line is 3/8 isnt it ?? i was just going to use that for the return..its already plumed in...or is that possible ??
post #5 of 10 (permalink) Old 02-21-2010, 07:46 AM
<<< Power
chvyrkr81's Avatar
Um, I don't think it is man. There are rubber portions to it that might be 3/8ths, but a large part of it is a steel line that's only 1/4 probably.
06
02
97
74
post #6 of 10 (permalink) Old 02-21-2010, 07:51 AM Thread Starter
hmmm she is parked for the winter..ill have to crawl under there and look..i was thinking it was 3/8 and the return was 1/4..if it isnt..then yes i will run a 3/8 return..
post #7 of 10 (permalink) Old 02-21-2010, 08:07 AM
<<< Power
chvyrkr81's Avatar
Ok, reread your post, the return is 1/4. That's what I was talking about.
And yes, the feed line is 3/8ths. I dunno about usin it for the return though. Not sure how it'd accept incoming fuel back in the tank sender. I imagine there's a check valve or something you'll have to disable. But, it'd be a good idea if you can gut the sender to make it work!
It's late, sorry for the confusion...
06
02
97
74
post #8 of 10 (permalink) Old 02-21-2010, 01:42 PM
Ron, your 17 should feed those Hybrids just fine.
BTW, Jody can tune for that Adr, no problem.
TerminatorEngineering is offline
post #9 of 10 (permalink) Old 02-21-2010, 10:03 PM Thread Starter
post #10 of 10 (permalink) Old 02-22-2010, 01:14 AM
Village Idiot
southmike's Avatar
sounds like a great plan to me...
I would love to do the same, only I'd leave the bowl in for now.
southmike is offline
