fuel pump? - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 17 (permalink) Old 02-19-2010, 06:22 PM Thread Starter
e99pstroke73's Avatar
fuel pump?
i have a e99 6 spd truck im fixing up. its got about 206k on it. turbo back 4" and a s&b intake, gauges and and stcok replacement clutch with about 40k on it. i have a sat of gauges on the way and want to order a tuner from dp. im gonna get one of th diy injector rebuild kits, and i was curious as to what you guys think i should do for a fuel pump. im on a budget and i think the pumps gettin ready to give out. if i build staged 1s is a stock fp good enough? also how much differance will the 17hpop make over the 15 i have stock?
e99pstroke73 is offline
post #2 of 17 (permalink) Old 02-19-2010, 06:52 PM
A Ghost these days...
farm boy's Avatar
Re: fuel pump?
If your not gonna go over stg 1's, put a stock pump back on it. Aftermarket pumps are alot of trouble. And hook up a fuel pressure gauge first. Those little things are worth there weight.
2002 F-250 4X4 Flatbed
~Cryo'd Forged Rods ~Comp 910's ~DI Push Rods ~ARP Studs ~IH Up-pipes ~GTP38R/1.15 ~238/80's ~Fuelab ~Built Auto ~Matt's Tunes ~Water Inj. ~Gooseneck Brand Flatbed
Rockin' Out with some help from: Alpine / Rockford Fosgate / Memphis / Infinity
farm boy is offline
post #3 of 17 (permalink) Old 02-20-2010, 02:57 AM
TARM's Avatar
Re: fuel pump?
I strongly second that. Nothing has yet proven to be as or more durable as the stock SD pump. For that fact I am going to dual SD pumps first rather than go to a aftermarket single specifically becasue of durability and tolerance. Stage 1's are usually good to 360HP max. The SD pump is considered plenty up to 400HP. Duals SD 550-600 HP.
IMO, best first to add a RR with external regulator and have it connected to the map to control the pressure curve based on boost. Take care of the rest of the fuel system from the tank to pump and pump to heads. Then if you decide to go up in power you need only to increase your pump capacity. It will give you the best fuel condition for your injectors as well until then.
TARM is offline
post #4 of 17 (permalink) Old 02-20-2010, 03:49 PM Thread Starter
Re: fuel pump?
whats a RR?
post #5 of 17 (permalink) Old 02-20-2010, 04:53 PM
white7.3's Avatar
Re: fuel pump?
Originally Posted by e99pstroke73 View Post
whats a RR?
Regulated Return
2001 F-250 4x4 ECSB
7.3 PSD DP Tuned
6.0 I/C Van Turbo & WW
6637 Intake 5" Exhaust
Custom RR Fuel System
05 Grille/08 Center Console
Raptor 372 w/ Toyo Open
Country AT2 35/12.50
white7.3 is offline
post #6 of 17 (permalink) Old 02-20-2010, 05:10 PM
white7.3's Avatar
Re: fuel pump?
Will dual superduty pumps work with my setup? im wanting to do a diy fuel system eventually and later put some mild injectors soon after...
2001 F-250 4x4 ECSB
7.3 PSD DP Tuned
white7.3 is offline
post #7 of 17 (permalink) Old 02-21-2010, 04:21 AM
tbolt's Avatar
Re: fuel pump?
Get the adrenaline hpop. It's about as cheap as a stocker and yes the 17 is better than the 15. I'm doing the hpop swap in the next week or two.
Glen
early99 f350 cc, lb, 2wd, drw, A pillar autometer guages, CTS monitor, AIS intake, 4" turbo back cat delete diamondeye exhaust, dptuner, pmt1, jw vb, Swamps ab inj, Adrenaline oil, Coolingmist, 180*T, Trucool cooler, spin on trans filter, Firestone air bags, 2" frt leveling kit, now chased by a 34' toyhauler
tbolt is offline
post #8 of 17 (permalink) Old 02-21-2010, 05:53 AM
TARM's Avatar
Re: fuel pump?
Yes but you will not need it until you hit 400 HP. What I like about two pumps is if you have one fail you still have enough fuel from the other to drive normally to get you home etc..
TARM is offline
post #9 of 17 (permalink) Old 02-22-2010, 03:14 AM Thread Starter
Re: fuel pump?
How hard is it to do a diy rr? im on a pretty tight budget but i definately want whats best for the truck
Early 99 build date 3-98 S&B intake, 10k, 4" turbo back exhaust, 4"lift 315-75-r16 pro comp extreme ats, 6 speed, stock clutch, super cab long bed sold
westminster, MD.
04 excusrion limited under construction
post #10 of 17 (permalink) Old 02-22-2010, 12:02 PM
farm boy's Avatar
Re: fuel pump?
How hard? Not very.
It will cost you around $300 in hoses, fittings, and regulator if you source everything yourself.
farm boy is offline
