Looking for MORE mods which way to go?? - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 11 (permalink) Old 02-19-2010, 08:16 AM Thread Starter
Ram
i have a 99 7.3 current mods 6-posi chip, built tranny, cold air, and stacks. im looking for some more hp that wont break the bank or a good decent mod that will def up the hp on my truck without having to do a ton of other things to it.
Ram is offline
post #2 of 11 (permalink) Old 02-19-2010, 08:37 AM
FORD..THE ROCK CRUSHER
Ron's power stroke's Avatar
Re: Looking for MORE mods which way to go??
Early 99 or 99.5 ??
Ron's power stroke is offline
post #3 of 11 (permalink) Old 02-19-2010, 01:11 PM
Death Row Inmate #7
strokin'_tatsch's Avatar
not too much more you can do on the stock turbo, but you can throw some injectors in it. If your chip doesn't have custom tunes get custom tunes put on it.
Travis
1995 F-250 SC 2wd zf-5
strokin'_tatsch is offline
post #4 of 11 (permalink) Old 02-19-2010, 03:16 PM
The Fireman
big_stroker's Avatar
There really isnt to much more you can do with out spending some cash.
An adrenaline HPOP would be 1st on my list
Then fuel system, new turbo and injectors.
and like strokin said some custom tunes if you don't have already
big_stroker is offline
post #5 of 11 (permalink) Old 02-19-2010, 03:31 PM
Buffalo Diesel
If I did it over again, it would have been tranny then Adrenaline and tunes.
Instead, I got the tunes, then had to do the tranny, now I have injectors, but I don't think I have enough oil.
Had I gotten the Adrenaline first, I'd have the same amount of power (I think) and I would have saved $1500.
2000 F350 CC LB - 250cc 200% - Matt Tuned - 9" Lift - 38" Extreme ATs - Vegistroke
Jack_Toepfer is offline
post #6 of 11 (permalink) Old 02-19-2010, 04:27 PM
Slated4Greatness's Avatar
What are your goals with the truck? DD? Towing heavy? Drag racer?
How much are you looking to spend?
P.S. I also didn't see that you mentioned gauges, that would be a first step for me.
2006 F350 Lariat Tow Boss W/training wheels.
SCT W/GH's tunes, ARP's, Blk & Heads milled, Strictly RR and aux coolant lines, 6" Aussies, Snow MPG-Max, BPD: VK688,EGR, W/Pump, and FICM, Coolant filt, Train Horns, CTS (Monitor only) + Autometer backups
RIP Muley 9-25-09
Keep on Honkin' Jerry 04-05-10
Slated4Greatness is offline
post #7 of 11 (permalink) Old 02-19-2010, 05:14 PM Thread Starter
Ram
its an early 99 my goal is like 400 hp or so i mean i am willing to spend a good amount on one thing for a good hp jump but i just want to go in right direction i was going to do some injectors but i was told i would need arp head studs and bigger turbo.. i mean im not towing at all basicly its strickly mud and drag.. what kinda custom tunes should i get i mean i have 4 positions that go up to 120hp and 220 ft lbs of torque then the high rev and valet.
Ram is offline
post #8 of 11 (permalink) Old 02-19-2010, 05:25 PM
Gauges
modded H2e
stage II inj
Custom tunes from Jody at DP-Tuner
This will put you right where you want with room to grow.
RIP Muley 9-25-09
post #9 of 11 (permalink) Old 02-19-2010, 07:21 PM
The Fireman
Originally Posted by Slated4Greatness View Post
Gauges
modded H2e
stage II inj
Good list but why would he want to switch to DP Tuner if he already has a 6 pos chip he can get reburned?
Also said he wanted to not spend much money
post #10 of 11 (permalink) Old 02-19-2010, 08:01 PM
you didnt say any thing about exhaust or intake..more air in and more air out will give you better power...cheap mods for the early bird to give you more power would be put in a 99.5 HPOP if you cant afford the Adrenaline right now..a new reman stock pump is around $380.. next would be the IDM from a 99.5 or gain about 20 HP by moding your IDM with 5 cent resister...in tank fuel Mod is also very helpfull..
