exhaust housings - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 20 (permalink) Old 02-19-2010, 01:19 AM Thread Starter
Crazy Talk
powerstrokenstang's Avatar
Send a message via AIM to powerstrokenstang
exhaust housings
is a 1.0 wastegated housing worthwhile on a stock turbo? truck tows alot and at most may get small stage 2's.
1996 F-250 ex-cab -D60- Motor,fire hoses-Nate,Tuning,Cam-Matt R,P-rods,dummy plugs-Wipe Out,Huffer-Engineered diesel,Carson,Gen3,Idm-Swamps,Rods,studs,fire rings-WOP,Clutch-Valair
455/400's in,S475 T-6 mounted
'84 f-350 2wd, 6.9l, 4spd, drw, flatbed. For Sale
powerstrokenstang is offline
post #2 of 20 (permalink) Old 02-19-2010, 06:30 AM
<<< THE GAUGE WHORE...
CSIPSD's Avatar
Re: exhaust housings
I would keep your stock housing IMHO... I dont think you would see much if any gain with stage 2's and a 1.00 housing. Any lag you have with stock injectors will go away when you almost double the fuel avalable.
Joe
CSIPSD is offline
post #3 of 20 (permalink) Old 02-19-2010, 11:23 AM Thread Starter
Crazy Talk
i am talking on a sd, its my tow rig. on real cool nights on the way home from pulls on a steep grade i get some surge. the ww cured most of it but i figured if it ever gets bigger injectors it would only get worse.
post #4 of 20 (permalink) Old 02-19-2010, 12:31 PM
dinnerbooter treasurer
genuineford's Avatar
A 1.0 waste-gated housing is stock on a super duty turbo.
93 F350 Gasser
03 F250 6.0
dinnerbooter #3
genuineford is offline
post #5 of 20 (permalink) Old 02-19-2010, 12:36 PM
CSIPSD's Avatar
.84 housing is stock on a superduty...
As far as stock turbos go and injectors... Bigger is better. A 1.00 housing is a great idea for a tow rig, if it towed less I would say a 1.15 housing would be even better.
My wife has a 1.15 housing on her 38r and its about perfect, but the 38r makes up for the slight loss of eff due to the 1.15.
Joe
CSIPSD is offline
post #6 of 20 (permalink) Old 02-19-2010, 03:56 PM Thread Starter
Crazy Talk
ok cool, now would a 1.0 gated housing be best or would a non gated be ok. i dont want to over boost or anything.
post #7 of 20 (permalink) Old 02-19-2010, 04:13 PM
<--Spy Vs. Spy
theSLEEPER's Avatar
If I were you, I'd try a ported compressor housing first and see how that works for you...
228-365-0698
Sheep only have two speeds, 'grazing' and 'stampede'.
Regulated Returns are on SALE!!
theSLEEPER is offline
post #8 of 20 (permalink) Old 02-19-2010, 04:48 PM
How would that help?
I have a 1.0 non-gated exhaust housing on my superduty. With stock injectors I can hit 32lbs of boost. I feel you might be close to destroying a turbo if you went to stage 2 injectors without a gate or detuning them a little. A gated housing might be a better fit if you want to run that large of injector.
You could try it with stock injectors for a while, I know mine tows awesome even on 35 inch tires. I tow heavy also. 300-340 hp on tap is all you really need for tow duty anyways.
For Sale: 2000 F350, black cc sb 4x4
Jngreen is offline
post #9 of 20 (permalink) Old 02-19-2010, 04:52 PM
<--Spy Vs. Spy
theSLEEPER's Avatar
Because it would help reduce the surge... I didn't realize he already had a WW though.
228-365-0698
post #10 of 20 (permalink) Old 02-19-2010, 05:50 PM
The 1.0 wastegated turbine housing is a must for a stock turbo. Limit it to 25-28 psi. The ported compressor housing is also a great upgrade, watch the classifieds for used ones.
2001 F-350 CC Drw, GT-4294/1.01, 200cc splits, AFE stage 2, custom fuel system, Rickson 19.5's, many more mods.
outlaw5.0 is offline
