stock head bolts.... what injector can i do? - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 16 (permalink) Old 08-02-2007, 03:34 AM Thread Starter
if at all possible has anyone run a small set of injectors for a while on stock head bolts with big oil?
how far can i push the edge getting like 35 lbs peak now with a small lag on the spool for even the 140 file
trx300exnj is offline
post #2 of 16 (permalink) Old 08-02-2007, 04:02 AM
Re: stock head bolts.... what injector can i do?
Injectors will have more of an effect on EGTs then the HGs, although they'll still affect the HGs. If you keep the timing under control you can put quite a bit of fuel in the truck and not hurt it. For a small increase in fuel you could do AC's, that'll get you around 160cc of fuel and if you do single shots all 160cc will make power. You could also get small hybrids, around 230cc and tune accordingly. What injectors really depends on how far you want to go and how much you want to spend.
69W900A is offline
post #3 of 16 (permalink) Old 08-02-2007, 04:06 AM
I'm running 180's with stock nozzle
no idea on boost bec it pegs my 30lb gauge, but I think headstuds are the least of my worries
gregrob is offline
post #4 of 16 (permalink) Old 08-02-2007, 04:12 AM
Village Idiot
southmike's Avatar
i would get something like hybrids 530's
you can alwys get them detuned when you get
your chip reburned. injectors are expensive
and you don't want to buy diff ones later.
southmike is offline
post #5 of 16 (permalink) Old 08-02-2007, 04:24 AM
Starting Over
kainers's Avatar
Hybrids run them with no ill effects on the HG.QSSB turbo and from what I have been told stock nozzles on the inj's then all the other BS goodies.Guess I should fill my sig back in again
kainers is offline
post #6 of 16 (permalink) Old 08-02-2007, 02:08 PM
AllYourBaseAreBelongToUs
imelmo's Avatar
Like David me when I got my mini-me's, probably 60-70% of the people running them w/o studs won't have a problem with head gaskets. But for around $700 it's relatively cheap insurance.
EMPIRE DIESEL, PERFORMANCE TRUCK PRODUCTS, CEN-TEX DIESEL PERFORMANCE, AND DIESEL INNOVATIONS
ALSO LOTS OF HELP FROM (IN NO PARTICULAR ORDER) TWISTED DIESEL PERFORMANCE, FCDP, ITP, MATT WITH GEARHEAD, ERIC WITH INNOVATIVE, DOUG WITH GOGO DIESEL, CASS WITH FULL FORCE DIESEL, AND SWAMP'S
2005 F350 Fat-Butt Truck
2004 ECSB Procharged F250
imelmo is offline
post #7 of 16 (permalink) Old 08-02-2007, 02:11 PM
Banning Smut
PTSUPERD's Avatar
Stock head bolts here. Beat the crap out of it daily on the highway for several years now.
No track time though....
PTSUPERD is offline
post #8 of 16 (permalink) Old 08-02-2007, 02:15 PM
imelmo's Avatar
You gotta make power to break stuff.
imelmo is offline
post #9 of 16 (permalink) Old 08-02-2007, 02:20 PM
Banning Smut
PTSUPERD's Avatar
Watch out! Its atleast 300 hp.
PTSUPERD is offline
post #10 of 16 (permalink) Old 08-02-2007, 04:01 PM
Laces Out
bigrpowr's Avatar
what danny said.....DA
08' F250 4x4 w/ 3:55's
bigrpowr is offline
