Another Blown TN BB Drop-In??? - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 4 (permalink) Old 02-13-2010, 11:42 PM Thread Starter
hotstik's Avatar
My cousin had the misfortune of purchasing a TN BB drop-in a while back. His first one #### the bed after only 20 miles, and now he's on his second one which has approx 15k miles on it.
Last weekend, the compressor side started pissing oil. So, we figured the turbo was toasted, as the leak was fairly substantial. Today he went to start tearing things apart, and it seems that the turbo has stopped leaking.
He had to drive it a couple hundred miles, to get it home, from when he first found the leak. So, it seems to have stopped at some point during that drive.
His crank case is vented to the atmosphere, and injectors were swapped shortly before the leak started (upgraded to Swamps 175's). All of the CAC plumbing was thoroughly cleaned during the injector swap, so we know the oil is not residual. The turbo shaft has minimal play.
Any ideas???
Thanks!
2000 F250 7.3L 4x4
2003 F250 7.3L 4x4
DP-Tuner
Empire Diesel
ITP Diesel
John Wood Automotive
One Up Offroad
Swamps Diesel
hotstik is offline
post #2 of 4 (permalink) Old 02-13-2010, 11:46 PM
<<< THE GAUGE WHORE...
CSIPSD's Avatar
Re: Another Blown TN BB Drop-In???
More then likely he had some kind of CCV blockage. I ran quite a few of those and they were all very sensitive to CCV pressures.
Joe
CSIPSD is offline
post #3 of 4 (permalink) Old 02-13-2010, 11:51 PM Thread Starter
hotstik's Avatar
A CCV blockage was my first thought when he started having the issue. The CCV vent line was checked. No kinks or oil puddled in a low spot.
2000 F250 7.3L 4x4
2003 F250 7.3L 4x4
DP-Tuner
Empire Diesel
ITP Diesel
One Up Offroad
Swamps Diesel
hotstik is offline
post #4 of 4 (permalink) Old 02-14-2010, 06:30 AM
Layson's Avatar
Dieseldog had a similar issue with his 38R... blocked CCV..
Layson is offline
